Transmission ?
Old Apr 16, 2003 | 09:33 PM
gween's Avatar
Transmission ?
I want to put a Powerglide trans in my 86 IROC .and still use the stock tourqe arm .Does any one make a kit for this .If any one knows please give me the name of the company
theberms@optonline.net
Old Apr 17, 2003 | 07:02 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
why would you want to use a
powerglide??
an f-body is to heavy, use a powerglide effectively
Old Apr 17, 2003 | 02:35 PM
gween's Avatar
First off I was not looking for a opinion on what trans to use. As for a Camaro
being to heavy for a powerglide you are wrong. I have 2 friends that run glides in
there 82-92 F bodys.1 car runs low 11s and the other 1 runs mid 10s . I also know
2 guys that run glides in there chevelles.
My car is being built for bracket racing. Not just to go to the track and try to put up
a big #. Please if you can't help keep you comments to your self.
Old Apr 17, 2003 | 06:37 PM
Car: 1984 Firebird
Axle/Gears: 4.10
i assumed that becuase you want to retain the torque arm you were talking about a daily driver, in which case a glide is not the way to go.
if its more for racing then a glide may work better.
i thought that i was being helpful given the lack of info you gave in your original post
Old Apr 17, 2003 | 07:31 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Originally posted by gween
First off I was not looking for a opinion on what trans to use. As for a Camaro being to heavy for a powerglide you are wrong. I have 2 friends that run glides in there 82-92 F bodys.1 car runs low 11s and the other 1 runs mid 10s . I also know 2 guys that run glides in there chevelles. My car is being built for bracket racing. Not just to go to the track and try to put up a big #. Please if you can't help keep you comments to your self.
Heavier cars can benefit from a 1st gear that gets them off the line, third gens included. He was trying to steer you to a better solution, and wisely at that.
Glides work best in lighter cars. Just facts.
If you wanna build a slug with no first gear.... go for it! You invited flames with your stupid tranny choice.
I'm going to go put a Ford flathead in my Chevrolet now. For consistency.
Old Apr 17, 2003 | 07:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Wow...
This must be why my brother-in-law's 66 327 PG 3.08 gear Impala would walk off and leave my brother's 66 396 400 3.08 Carpice, after they got up fast enough that the 327 overcame the 396's 1½ car-length jump.... the Impala must have been a light car.
The reason you run a Glide in a bracket car is because you just build a monster motor, put in a throttle stop and timer to control how much power it puts out for how long, buy a converter of the appropriate stall speed for the motor, gear the car so it traps at the RPM you want, and run within .02 of your dial-in every time, no questions asked. If you can get your reaction time down below .510 consistently, you can bring home the money pretty often.
AFAIK the B&M "Turbo 350" kit should work for a PG, since it moves the torque arm mount to the crossmember. I'll warn you though, you won't get very consistent 60' times with that stock torque arm rubber-band POS in there.
Look at Spohn, advertiser at the top of the page, he makes a torque arm that replaces the stock one and also does what the B&M kit does; much better setup for what you're trying to do.
"Chrome don't bring the money home"
Old Apr 17, 2003 | 08:38 PM
gween's Avatar
I can see you have no clue how to build a good bracket car . In a bracket car you
don't want it to spin. You want the car to repeat ever run. My camaro should only
be like 3100 LBS that is not heavy. What do you consider heavy for a race car? Just
because you are a jack *** and know nothing about bracket racing my trans choice
in dumb. Again I have 2 friends that use glides in f body's and have no problems with
them and the cars are deadly consistent.On top of all that way do you guys give 2 sh*ts what trans I use I asked for help with something I get all this BS I know what works and what I want to do. Again if you can't help keep your comments to your self
gween's Avatar
Originally posted by RB83L69
Wow...
Thanks for your input.
Old Apr 17, 2003 | 08:52 PM
jmd's Avatar
jmd
I can see you have no clue how to build a good bracket car . In a bracket car you don't want it to spin. You want the car to repeat ever run. My camaro should only be like 3100 LBS that is not heavy. What do you consider heavy for a race car? Just because you are a jack *** and know nothing about bracket racing my trans choice in dumb. Again I have 2 friends that use glides in f body's and have no problems with them and the cars are deadly consistent.On top of all that way do you guys give 2 sh*ts what trans I use I asked for help with something I get all this BS I know what works and what I want to do. Again if you can't help keep your comments to your self
You didn't post that it was for a bracket car or none of this would have been said. firechicken_3 was trying to help and you flamed him because you made an incomplete post. Flame back all you want. Your post is the reason for all this.
Just remember, everyone is a jackass and knows nothing about bracket racing, when you never mention the application in the first place.
Why do we give two ****s about what trans. you use? Well, except for your bracket racer, and light drag-only cars, powerglides are a poor choice. That, along with your inconclusive post #1 was the reason for post #2.
-Matthew
Old Apr 17, 2003 | 08:56 PM
gween's Avatar
-Matthew
Why does it matter what I was going to use it for ? I asked a question and was
looking for a answer. That was it. If you don't have a answer then don't reply plan
and simple.
Old Apr 18, 2003 | 12:40 AM
Car: 1984 Firebird
Axle/Gears: 4.10
ok i did not mean to start a flame, by replying here. but
rb and gween have made good points about a glide being good in a bracket car. with the big motor, throttle stops, etc... and not want tire spin, but needing consistency.
so you are right to want to use a glide, the reason i questioned your idea of a glide is due in part to 3 things
1. lack of info in original post(true it doesn't really matter to me what trans you use)
2. this is probly the biggest thing Curiosity on my part, due to reason number 1
3. the general opinion among drag racers that i know is that about 2500lbs is a good cutoff for effective use of a PG.
i know you did not want a reply unless it gave you an answer i believe rb was able to do that. the reason i have replied once more is to clarify my reasons, learn from my mistake, and attempt to keep in good standing with this message board as generally it has been very helpful
have a good day
Old Apr 18, 2003 | 12:44 AM
jmd's Avatar
jmd
I answered that in my first post in this thread. Wake up, pay attention, and enjoy your antique parts.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
