Found some 9 Bolt gears, will these work?
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I found a set of 3.23 gears from a 9 bolt. are these 2 series gears that can take the place of my 2.77 gears i currently have? all i gota do is swap the gears and re-shim it right?
what am i missing here? the gears are $180 is that a decent price?
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Actually there is now a 3.23 ratio available for the 9 bolt. I have them in stock. For 180, it's definately not a new 9 bolt gear though.
The only other ratio that will fit directly on series 2 carrier is a 3.08 Everything else (up to 4.10) requires a series 3 carrier.
Miles
Diff Solutions
www.9bolt.com
Miles
Diff Solutions
www.9bolt.com
Transmission: 4l80e
Axle/Gears: 3.512
so if it IS a 9 bolt gear, 3.23, then it will fit in my 2 series carrier?
the posi is slipping right now, if i put those 3.23's in can i just re-shim the posi to make it stick once again?
and is that it?
and is that it?
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Miles
Diff Solutions
www.9bolt.com
Miles
Diff Solutions
www.9bolt.com
I had a 3.27 in my 9 bolt stock. You might want to check out www.9bolt.com they have complete install kits and carriers.
Transmission: 4l80e
Axle/Gears: 3.512
... and charge $1100 for all the parts i would need...
No, i think i will put in a 10 bolt. this will be a street car, so a simple SLP zexel, some motive gears, and some used 28 spline axles will fit the bill. i just wont hook, thats all. been there done that.
Transmission: 4l80e
Axle/Gears: 3.512
yeah but ive had mine on order for 3 months now and i called they said they had mine but it was missing the paddle pin thing so they were goina get it and ship it out soon. worst comes to worse ill get an eaton unit...
hectre13
Dec 11, 2023 08:14 AM
rsrmoore
Aug 7, 2015 08:44 PM
