What trans for 400hp& trq
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Ive just heard that the bw 4 spd (muncie also) has the shifter
located next to the transmission opposed to on top
like the 5 spd..
I need a trans that will hold up to a 400hp&trq 350 cu.in.
Would a th350 or 400 be a better choice ?
I just my car to be a reliable strret car& weekend racer.
Highway driving is a must also ..
like the 5 spd..
Engine: 3.0L/183
any opinions ?
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
well do you want a stick or an auto? Any auto will hold that much if bult properly. For manuals anything except a T5 (read t56 or a tremec).
Engine: 3.0L/183
when I look at this car.. I see a sports car...
it should be standard.. but $$$ .. auto is
less expensive.. Ill probably go that route..
unless I find a deal 4 a 6 spd.
thanks
ps. I heard that I should go with a 6 spd motorsport ??
Is that trans beefed up from the factory?
thanks
1992 Trans Am
05-10-2023 07:19 PM
