Is this normal with the T5?
Old Apr 18, 2003 | 12:50 AM
Bugsy's Avatar
Ok, I don't know if this is normal or not so thats why I'm asking.
Ever since I can remember, whenever I shift from one gear to another, I hit two points of resistance while throwing the shifter. In other words, lets say I'm racing and when shifting from 1st to 2nd or 2nd to 3rd etc., it doesn't shift 100% smooth like when going just from one gear into neutral. It kinda hits two points of resistance that make shifting fast kinda tricky. Is this normal?
Thanks,
Bugsy
Old Apr 18, 2003 | 12:52 PM
Bugsy's Avatar
bump...because posting late at night sucks
Old Apr 18, 2003 | 01:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
The point where it stops midway between neutral and next gear, is the synchro ring ("blocker ring" is its official name) blocking the shifter from going any farther until the internal transmission parts have equalized their speed. Once everything is turning at the correct speed for the gear you're shifting into, the blocker ring quits blocking, and the shifter can then move the shift sleeve the rest of the way into gear, where it engages the teeth on the gear.
Yes, it is normal. It is an inevitable part of how the transmission works. If it didn't stop the shifter from moving, it would grind the hell out of the shifting teeth. All manual transmissions work that way.
Old Apr 18, 2003 | 11:57 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
powershifting is bad mmmm-kay
Old Apr 19, 2003 | 01:30 AM
Bugsy's Avatar
Thanks for the info. Also, is it actually hard on the tranny then when ripping it into gear at the track?
Old Apr 19, 2003 | 05:44 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
yes. It is pretty bad.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
