2.73 to 3.42
Old Apr 18, 2003 | 09:35 AM
kdgreen's Avatar
2.73 to 3.42
I went from 2.73 to 3.42 gear in my 91 Camaro RS. Now the Speedo is like 15-20 off. How do I go about figuring what I need to fix it? I will have the tranny out this weekend for a stall and shift kit so I might as well fix that too. Thanks.
Kevin
Old Apr 19, 2003 | 12:28 AM
25THRSS's Avatar
I'm not sure what speedo gears you need, but how much of a difference did the 3.42's make?
Old Apr 19, 2003 | 02:29 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Did the same to my 86 Camaro. Massive difference in bottom end power. Well worth it. I'd guess about 4/10 in the quarter.
Since mine is so much older than your 91, the whole set up is different. I needed a sleeve and driven gear, but maybe your's is the electronically programmable type of speedo???
Old Apr 19, 2003 | 08:50 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
Nope. It's electronic but not totally. You have the Two gears the driven and drive gears. the only thing different then that is that there no cable it turns in a electronic signal from the housing out. hope that helps. i'll tell you how mine goes. I have a 1992 camaro. and i went from a 2.73 to a 3.73.
Old Apr 20, 2003 | 12:42 AM
Trevor K's Avatar
Shouldn't be hard to find - go to a dealer because the RS's also had the 3.42's, so just ask the parts guy.
Old Apr 20, 2003 | 02:48 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I changed the driven gear when I put the new trans in my car, but I haven't changed the drive gear(was told I didn't need too. I have 2.73's, putting in the 3.70's next wednesday. The change in indicated speed wasn't as severe as I thought it would be, maybe because of the new trans and TC or because I didn't change the drive gear?
Old Apr 20, 2003 | 07:28 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
you need to change the drive gear, or you will never get it right
Old Apr 20, 2003 | 10:47 AM
v8unleashed's Avatar
get a 45 driven and a new carrier for the gear and it will be close enough
or run a SEARCH
Old Apr 20, 2003 | 02:37 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yup...search is good.
However, go to www.700r4.com and play around with their gear calculator. I even found it for ya:
http://www.700r4.com/SpeedOCalc/
Have fun!
Ed
dbrochard
Jan 28, 2016 08:42 AM
JSDaddy189
Sep 26, 2015 03:50 PM
64Chief
Sep 12, 2015 08:05 AM
john204481
Sep 7, 2015 03:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
