vigilante stalls worth the $$$?
Old Apr 20, 2003 | 08:46 PM
19WS6T/A91's Avatar
vigalante claims .5 et gain. that sounds like alot to me. will i really see a gain this big? also what size stall should i get on a basically stock 350. in the furture i plan on an lt4 hotcam and heads, until then the car is stock with bolt ons. i just dont want to spend 700 on a convertor whenn one for 500 will be the same.
thanks,
David
Old Apr 20, 2003 | 11:17 PM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
he11 yes its worth it you get what you pay for with converters i had b&m 2200 i was pulling 2.0-2.2 60 fts now i pull 1.6-1.8 60 fts they are worth every penny im running a 2800 vig later
Old Apr 21, 2003 | 02:02 PM
19WS6T/A91's Avatar
one other thing, what is the little black dot in the bowtie next to my post? can anyone speak for the vigalante convertors? what kind of gains have been seen?
thanks
Old Apr 21, 2003 | 02:06 PM
Car: 92 camaro
Engine: 383 stroker
i went from 13.0 to 12.4 in 1/4
Old Apr 21, 2003 | 02:45 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
thanks
that just tells you that you have a post in that topic/thread
Old Apr 22, 2003 | 06:50 PM
19WS6T/A91's Avatar
i know that more people out there have vigalante stalls...
Old Apr 22, 2003 | 08:05 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
what is a vigilante stall converter?
Old Apr 22, 2003 | 09:37 PM
Mark 89Formula's Avatar
I saw an ET improvement of about 4 tenths over the stock converter. 2 tenths of that was in the 60' time and 2 tenths from the improved torque multiplication down the track. This is on an internally stock L98 with exhaust and the free/cheap mods. I went with 2600 RPM stall since my combo is so mild.
Old Apr 23, 2003 | 01:57 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
ANyone noticing any losses in fuel economy around town with your 2600-2800 stall converters? thats my biggest worry.
Old Apr 23, 2003 | 06:04 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have a their multi disc converter @ 2800 rpm. It does exactly what it says on the tin! Great piece of kit.
Old Apr 23, 2003 | 07:00 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I went from 13.0 to 12.5 directly after installing it.
Tim
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
HoosierinWA
Oct 7, 2015 10:15 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
