G-Force T-5???
Subscribe
May 7, 2003 | 03:59 PM
  #51
Exactly what he said....
I dropped them an E-mail yesterday - still no response.
Reply 0
May 8, 2003 | 11:24 AM
  #52
Update: I called them, and nothing but bad news on my part.
I just wanted to confirm what was stated earlier in this post- and yes, the upgrade is for WC only. (88-92)
They won't even take my poor old Borg-Warner in trade.
In short- this kinda sucks for me. Looks like I'll have to pay the full 1950 bucks plus 130 for shipping if I want the tranny and G-Force upgrade, so I'm down to getting a few opinions.
So - If you had an older T-5 like me - would it still be worth it to get this tranny ?? Or should I try the T-56 swap??
Moneywise, I'd still most likely end up spending more on a T56, with the tranny mount, clutch, flywheel etc. that I'd have to change.
At present, it seems like my tranny is on it's way out - and just in time for summer. When I push in the clutch, I get a grinding noise most of the time and no amount of clutch adjustment seems to get rid of it. Good Times !!
Opinions appreciated...
Reply 0
May 8, 2003 | 03:26 PM
  #53
You can buy a used w/c t-5 for $300-500 and get the kit for $1,000 then buy 'How to rebuild a t-5' from Hanlon Motor Sports for $25 shipped and build your own for far less (and easier) than a T56 swap. I bought the video and it isn't rocket science to rebuild one.
Reply 0
May 8, 2003 | 03:48 PM
  #54
Let me get this straight... you only here the grinding when you push the clutch pedal down do the floor? You dont hear it when you let the pedal up from the floor? If this is the case, it sounds like you have a bad Throw-Out bearing. If all is quite while the engine is running in neutral and your foot is NOT on the clutch pedal, then all is O.K.
Now let me ask this, does this noise only happen while you're shifting, or does it happen whenever you push the clutch in?
Reply 0
May 9, 2003 | 12:44 AM
  #55
Quote:
Yeah, I agree, if I can find one at a reasonable price...say 200-350, I'd do it. I can get a shop manual from the library for assembly. Definatley cheaper than 1945.00 + shipping for the whole thing. Forgot to see what thier warranty was.
I'll most likely end up doing just what you say.....thanks.
Only problem I see is if I have to press bearings on and off shafts - I don't have a press.
BTW...the tech at G Force says the older non WC T-5s have a "different gear arrangement".
Reply 0
May 9, 2003 | 01:08 AM
  #56
A little history on my car..
Well, the tranny was grinding so bad that the car was parked and not driven for 4 years, then I bought it. It was run without fluid. It completly ate up a flat needle-thust type washer attached to the main shaft. It just wasn't there when I took it apart, but I found metal shavings in the bottom of the housing.
Anyways - I bought a new bearing, installed it and I still have a bunch of axial and radial play in it. Somthins up. Only has less than 3000 since I did this. But been great up to now.
Sounds like a bearing grinding, and I can actually feel the vibration it in the shifter when I sit at a idle at a light. Anyway - I'm assuming it's the same bearing going out again.
Do you think it could still be the throw-out bearing?? I just don't know why it would fail this quick though.
Alot between shifts, and occasionally when I push in the clutch to stop at a light. Sounds horrible. Sounds like I'll be pullin it all apart soon no matter what.....again
Reply 0
May 13, 2003 | 03:43 PM
  #57
I called and asked how long the wait was and got a 3 week lead time. Good thing I asked. He said they are very busy and have a backlog.
I asked about any succes stories and he talked about a 9 sec mudpuke in florida running this tranny combo using the dog ear which he claimed is just as strong as the sync one.
I'm doing it! It sure would be great if it was cheaper with a GP
Reply 0
May 21, 2003 | 01:36 PM
  #58
I decided to just buy a complete synchronized T-5 from them, but they don't know if they have a Chevy case or not. Guy said he normally deals with Mustangs.
Of course I had to ask a few questions. Upgraded gears- Yes, Pro 5.0 shifter- Yes - but any warranty - NO!!!!
They said all their trannys function perfectly before they leave, and since thier street/strip upgrade is a "racing transmission", they have no warranty.
Anyways, there going to call me back today to tell me whether they have a case for mine or not.
So what do you guys think??? Would you still get it if they told you No Warranty????
Opinions????
Reply 0
May 21, 2003 | 06:00 PM
  #59
I was very up front and said that it will get real bad reviews if it takes a crap after a few trips down the track and you don't fix it. He said that they are stand up guys and if they biuld it they will assess the situation and do the right thing.
I'm cool with that.
Reply 0
May 22, 2003 | 12:30 AM
  #60
Hey Dwayne88IROC - Are you getting the whole tranny like I'm asking about??
I'm just wondering how they would "assess the situation".
I was just hoping for a workmanship and material type warranty - something like if it's a breakdown due to bad clearances, or a cracked case, then they'd take care of it. The guy just reinerated that thier trannys are in "Perfect working order" when they ship them, and no warranties are implied.
Call me cheap, but when I'm interested in buying a 2000.00 plus (with an upgraded Pro-5.0 shifter) tranny - that's a chunk of change to throw around and not get a warranty.......or am I just spazzing over nothing????
BTW...they didn't call me back today like they said...
Reply 0
May 23, 2003 | 10:38 AM
  #61
Wow...normally you get all kinds of opinions....
Reply 0
May 23, 2003 | 11:55 AM
  #62
I'm sending my stock WC T-5 for them to install the kit.
He said if a part fails they will replace it. Problem is getting it to them if something does fail. I would assume any company that wants to keep open would back their stuff somehow.
What kind of warranties does Jerico offer?
Reply 0
May 23, 2003 | 12:59 PM
  #63
I won't even bother with a Jerico. Since it's more of a racing trans, I doubt there is any warranty on that.
I'm just waiting on a response I should've gotton a couple of days ago about an entire upgraded WC T-5 from them. They said they'd have to check the warehouse to see if they had a Chevy case. Said they would call me back that afternoon to let me know.
They didn't call me back for two days, but I did get a survey for their customer service in my e-mail. Needless to say, I had a few comments.
I just got an e-mail back from the survey this morning and it says they will call me today about it. The saga continues.
There are a few that posted above about buying either a kit or having them rebuild one. If you have any comments good or bad so far for G Force, please post them. After what I've been through so far, I'm getting a little skeptical.
Dwayne88IROC - I'd assume that you would have to pay to get your tranny shipped to them in order for them to repair it. That's why I was interested in some type of warranty for defects from them. If I shredded the thing while I was speed shifting and abusing it, I don't expect the warraenty to apply.
But if there's a problem from day one, under normal driving, I think they should back it up. They say they will take care of it over the phone, but will they remember that if it actually happens after you buy it?? I'd prefer that info to be in writing.
Reply 0
May 23, 2003 | 01:47 PM
  #64
No one should want a dog ring trans for the street, they whine like crazy and are hard to shift. I want a synchro one but I have the same problem as confuzed1... my trans is non-WC. And what is the deal with not having a chevy case? That kinda sucks.
I'm sure they are just getting a little busy from this kind of publicity, I want one though.
Reply 0
May 23, 2003 | 04:23 PM
  #65
Tom -
Yeah, I wouldn't want a dog-ring trans for the street either. I've been asking them about the synchro type. It baffles me why they don't have a case either. But then again, maybe they do, but they haven't call me back yet.
Maybe you're right...their just busy..
Reply 0
May 25, 2003 | 01:34 PM
  #66
Quote:
Originally posted by Scott C
You Guys will be the first to know :lala:
Hi Guys, it's me! My account was disabled for some reason, so I've registered under a new name...
Anyway, I sent my WC T5 to G-Force and already got it back!! They only had it for about 1 week. I dealt with Bubba through the entire process. He is a good Guy. He returned each of my calls if I didn't catch him live, and he even called me a couple of times to get my approval for additional parts! I needed 3 sliders and he called just to make sure I was aware...That's customer service!
I haven't installed the T5 yet as I'm doing a complete auto-manual swap. I don't expect to have any issues. but if I do, I am confident that G-Force will stand by their product.
BTW, the total cost including return shipping was $1,435.00. I'm quite pleased with the deal so far!!
Reply 0
May 25, 2003 | 04:29 PM
  #67
Hey scott c-2, did u get the 1st-4th gear set and the hardened mainshaft? also does the kit come with syncros? and is there anyting i should know be4 i send mine out? oh yea how did u send it to them? did u have to build a crate or something?? thanks man
Reply 0
May 25, 2003 | 04:30 PM
  #68
Damn... he beat me to it.
Congrats! Let us know how the T-5 performs!
Reply 0
May 25, 2003 | 05:09 PM
  #69
Glad to hear it Scott C-2. Bubba is the same guy that's been saying he'll return my call!! They must be doing good business, cause so far, they don't need my money!
Guess that goes to show you that two people can deal with the same guy, and get completely different results.
Maybe I scared them when I asked about any warranties....I don't know. Whatever. Bubba was supposed to call Friday, he didn't so I seriously doubt he'll call Monday either.
Happy to hear you are confident they'll stand by their product.
Reply 0
May 25, 2003 | 05:24 PM
  #70
Quote:
Yes, I got the 1st-4th syncro gear kit.
No, the hardened mainshaft is only for Mustang T5s.
Just pack the trans in a good, heavy box with extra heavy cardboard and/or styrofoam around the trans. You want it packed tight so the trans doesn't move at all when the box is manhandled by UPS.
Reply 0
May 25, 2003 | 05:32 PM
  #71
I simply called Bubba, spoke with him about their T5, told him I was dead serious about getting it done right, and told him I would ship it to him ASAP. I bought their prototype input shaft as well. That's all they had available in stock so I took it (at a discount). Otherwise, the wait was at least 2 weeks...
If you're straight forward and let them know you are serious about the trans work, then you should have no problems.
Reply 0
May 26, 2003 | 12:17 PM
  #72
Prototype input shaft eh!
What's the scoop on that? Bigger, better?
I borrowed a tranny case from my local chevy dealer parts department. It's a large plastic shell made for shipping trannies. They had quite a few laying around.
Reply 0
May 26, 2003 | 12:55 PM
  #73
does the kit come with syncros??
Reply 0
May 27, 2003 | 09:18 PM
  #74
I also recieved an Email that contained prices, and some info not mentioned in this thread. So I thought I'd post it below.
Quote:
Hello,
I'm sorry it took so long to get back to you but we've been totally
buried with work around here. We made our first 25 T-5 kits and sold
them before they were even finished, so I wanted to get some more on the
shelf before I replied to your email.
Our T-5 kits are avialable in either synchronized or dog-ring
versions and the dog ring kits can be selected in either straight-cut or
helical configurations. If your mostly going to drive it on the street
and the lowest elapsed times are not the primary objective for the car,
then the synchronized kit would be your best choice. The synchronized
kits are only available in helical configurations, for reduced noise.
The dog ring kits are best suited to cars that are primarily used at
the track. They can be driven on the street, but they are a bit
"clunky" when shifted, especially driving through town. I have a
dog-ring kit in my personal car (a 2000 Roush GT with about 550
RWHP-check out the cover of the upcoming MM&FF tech guide) and it's not
bad at all around town if you don't mind a bit of clunking in the gear
change. A had our synchronized kit in the car before I put the dog-ring
kit in and both work excellent, but I opted for the dog-ring kit so
other people could see and feel how they shifted.
The synchronized kit utilizes 9310 high-nickel gear sets, input
shaft, countershaft, and mainshaft gears. The dog-ring kits utilized
the same 9310 parts listed for the syncro kit, plus new dog-ring
sliders, hubs, and bronze shift forks. We've made bronze forks
(aluminum bronze-very tough) that are optional on the synchro kits but
mandatory on the dog-ring kits, mostly because of the increased shock
load of the dog-ring operation.
We also have optional upgraded mainshafts made from either 9310 or 300M,
depending on the application (and how much you want to spend).
Both kits are rated at 600 crankshaft horsepower with the 9310
mainshaft, but this is only an ESTIMATE. It is based on running drag
radials or a small slick (something like a 26 x 10), with a moderate
clutch setup in a vehicle that weighs approx. 3000-3200 lbs. Use your
own judgement to determine if your vehicle will be more or less abusing
to the trans based on what you have for a setup. I can say, however,
that we did have a car in Florida this past weekend with our helical
gear kit running 10.0's and didn't hurt it (with the 300M mainshaft).
They are realistically the best horsepower per dollar purchase that you
will most likely find for anything over 300 horsepower.
All kits are either finished or in process and we should be ready to
ship everything in the next 3 to 4 weeks, but most are available today.
The prices for the synchronized kits are $1,000 using your trans and
$1,600 using a good core that we supply with the kit already installed
(assuming you don't have a T-5 to start with). The price on a dog-ring
kit is $1,550 using your trans and $2,100 using a good core that we
supply. You can also purchase the kits installed using a NEW T-5 for
approxamately $400 more. You can also send us your T-5 and we'll
install the kit for an additional $250 above the price of the kit. All
prices are without a shifter. We also sell Pro 5.0 shifters if you need
to get one (must have aftermarket shifter with stops for the dog-ring
conversion).
If you are a dealer and are looking for a buy in, contact us by
phone with your tax # and we can give the information that you need.
Thank your for your interest in our transmission components.
Michael Long
V.P. G-Force Transmissions/Long Shifters
Reply 0
May 30, 2003 | 10:08 PM
  #75
wow. confuzed-1 , notice that Scott was a serious buyer that was ready to go. I have dealt with G-force in the past on a 4-speed and have also used them since they bought Richmonds old 5-speed design and improved it for ultimate TRACK ABUSE. G force is a VERY good and very large company and i have never had a problem with them. Rich runs an IHRA SS/O 66 Impala, 4000lbs, 283 single 4 bbl that runs 11.60's with a G-force 5-speed with 5th gear removed. If i had someone hemming and hawwing about a warranty, I know that they probably werent serious anyway. Say you put it in and for some reason it is locked in gear and wont shift, then Yes they would resolve that problem and other slike it, but warranty against breakage on a Hi performance part is kinda useless. Face it, you are not ever going to put down enough power to kill one of their built units! All the information you would need has been posted, so go buy one already and show us how you're going to break it.
Reply 0
Jun 1, 2003 | 12:18 AM
  #76
I can't really tell whether you're just being sarcastic or what nicksL98. I was also very serious about buying one. I don't believe I mentioned a "High performance warranty".
I stated in the post above "materials and workmanship". Any reputable company should back that up. Sure, if I go out and thrash it mercessily and it breaks - uh....... no, I don't expect them to fix it. If I recieve it with a cracked case, or as you say - the gears are screwed up, them I would hope I'd have no probs with them.
Simple fact of the matter is, that they don't have a case as stated both in the G-Force message above or on their website. Bubba suggested I find a case and send it to him, and it would be cheaper - and I agree.
Well, I can't find one anywhere around here, so I told them I was interested in getting a WC T-5 from them with the upgrade kit already installed (and yes they supply the case). I'd wait a few weeks if I needed to.
Glad to hear people backing them up though. Anyways, I am still trying to clarify if they can sell me the whole trans or not. If so.... I'll get one. If not, a T-56 swap would still work well. -
Reply 0
Jul 14, 2003 | 02:27 AM
  #77
Excellent news!!! I was actually having to dread putting in a T56 but after reading this, I am so psyched about dropping a 350 in my car now. Keep this topic bumped!
Reply 0
Aug 12, 2003 | 08:23 PM
  #78
keep it up
Reply 0
Aug 30, 2003 | 07:27 PM
  #79
$1000 for there rebuild kit right?? what is included and do they sell like a cheaper version or kind of stage 1 ,2,3 kits??
Reply 0
Aug 31, 2003 | 01:39 PM
  #80
i have a tremec tko in my car, and id rather pay the 2000 bucks for that and bolt it in like 2 hours than take a t5, pay 1000 bucks for a rebuilt kit and spend the time pressing gears and rebuilding the internals, and still have a t5 case.
it took me 2 hours to install the tremec, all i did was bolt the plate to the tranny, bolt the spacers in the car and slide the bitch in there.
no need to modify the shifter hole, no special driveshaft needed the kit comes with a 1350 series yoke for the driveshaft which is way stronger than the stock size yoke.
that doesnt sound like much of a deal to me
Reply 0
Aug 31, 2003 | 11:28 PM
  #81
Anyone have a spec list of a tremek tko Vs. the g-force tranny as far as what costs and handling capabilities would be between the two? He does raise a good point, but $1000 is $1000 that a lot of us probably don't have, but I would like to see what one can handle against the other.
Reply 0
Aug 31, 2003 | 11:50 PM
  #82
I'm in. Just converted to T5 WC. I'll pop it out again at Christmas and do the rebuild. Heck Yeah.
Reply 0
Sep 1, 2003 | 10:01 AM
  #83
Quote:
the TKO is rated at 550 ft/lbs, but there are lots of people around here putting way more power to them than that with no problems.
im making over 500hp at the flywheel and i beat the living hell out of my tko, it never makes a peep.
now a full on g-force transmission, thats a different story....but not many people can afford one of those
Reply 0
Sep 1, 2003 | 11:20 AM
  #84
just to look up specs and prices for myself, how sells the tko's? I'm about to check jegs and summit, but if they don't have them who else does, and maybe for cheaper? thx
Reply 0
Sep 1, 2003 | 01:08 PM
  #85
there are like 2 people in the country you can get them for chevy's......one is forte's.....where i got mine, and the other i cant remember.
tremec doesnt make the tranny for chevy's, the case is modified and the adapter plate made by the companies that offer them
i got my TKO II with all necessary hardware, adapters, yoke, and shifter, (stock one sucks ***) and i bought a pro 5.0 shifter for it at the same time, it came to a total of about 2400 bucks.....the transmission itself is $1975
Reply 0
Sep 3, 2003 | 12:40 PM
  #86
Can't say I feel bad at all for buying the G Force trans so far. Shifts smoothly (synchronized), I also got a Pro-5.0 shifter and what a diff!!
Only took me as long to install as a stock trans would, and no "adapter plate", no shifter hole relocating, no special driveshaft yokes. As for the stock case, If what they say is true about having them installed in several 10 second or better strip cars, and they still hold up, well.....you be the judge.
Plus I got the .59 ratio 5th gear which helps big time on the highway. Instead of pulling 2800 on the road doing 70 MPH, I now pull 1800 RPM's!!
Oh........and it's rated higher in both torque and HP then a Tremec, and cheaper too.
Doesn't sound like much of a deal???
Reply 0
Sep 3, 2003 | 12:44 PM
  #87
BTW.....I have nothing bad to say about Tremec's. They'll easily handle gobs of power...... I was considering getting one also.
Reply 0
Sep 3, 2003 | 07:53 PM
  #88
confuzed, im not bustin your chops, just trying to make a few things a bit more clear......
ok let me say it again.....it doesnt take any longer to install the tremec than it does a stock t5, unless your a retard.....
the adapter plate is just 4 bolts that bolt to the bell housing....
YOU DO NOT HAVE TO MODIFY THE SHIFTER HOLE
IF YOU MAKE ANY POWER YOU OUGHT TO HAVE A 1350 YOKE anyways, you wont catch me leaving the line with a 1310 series u joint on slicks at any RPM
It took about 2 hours to swap the t5 for a tremec, done and done
its not cheap enough to justify buying a t5 in favor of a transmission designed for performance applications
THe transmission cost $1975 bucks, and is being reliably used in 800+ hp applications, and has been for years.
allow me to explain the t5 problem more clearly.....the inherent weaknesses of the t5 are well known, the worst being the case which can flex under load, causing misalignment and broken parts...regardless of how tough your internals are.
Are there people using t5's running in the 9's??? absolutely, but only a handful, and they are goddamn lucky, because the t5 problems are not a myth, its not a transmission designed to be abused like that.
This debate is like everything else in motorsports.....people will look for any opportunity to expound their greatness.....the mentality goes something like this, "i have a t5, and i can do such and such with it, therefore its a good transmission and no one can tell me different."
having been involved in professional motorsports for sometime now, i can tell you from experience that this arrogance about "what i got" exists at all levels in all parts of the country.
you can be at a race and have some nutjob tell you that your lenco is junk because my $15 th400 i got from the junkyard can handle more power.....right cleetus, thanks for the tip
G-force makes excellent transmissions, pricey as well i might add, but no matter how you build a t5, its still a t5, and i wouldnt spend any amount of money in a peformance application on a t5 of all things....these transmissions have always had trouble handling stock applications......
im all set with saving a few hundred bucks so i can spend another few thousand down the road, cause i still have a t5
Reply 0
Sep 3, 2003 | 08:28 PM
  #89
Quite the response..... I really didn't expect words like "retard" or "nutjob" to appear on a simple discussion board about trannys.
I agree with the use of a 1350 series yoke, vice the weaker one. I'm pretty sure that the stock rear wouldn't hold up either.
But, If you think I am trying to convey that "my trans is better than yours", then you'd be mistaken. There's no "trying to expound greatness" anywhere in my post.
So far as the casing flex goes, it doesn't take a rocket scientist, nor a professional racer such as yourself to figure out that if you apply enough torque, either case will flex, and either trans can be destoyed. Besides, it's the torque that kills them, not just "800 plus HP".
If a Tremec can handle it - great. I'm not here to "put down", or brag about "what I got".
But just for the record, I didn't say anything about having to relocate the shifter hole for either trans??
Anyhow, there ARE other options out there for trannys and to boldly state "Doesn't sound like much of a deal to me", is just an opinion and should be treated that way.
I don't feel as strongly about my G Force trans as you do about Tremecs obviously, but people will still come to thier own conclusions.
Reply 0
Sep 4, 2003 | 03:13 PM
  #90
ok, first off i said in the beginning of that post, that i wasnt taking aim at you, i just wanted to make some points clear,
and the part about relocating the shifter hole was quoted from your previous post, where you said you didnt have to do that.....
i was stating that you dont have to do that with the tremec either, and wanted to make that clear because people have said before that it was necessary,
as far as case flex goes, of course any case will flex with enough power applied to it, but a t5 case will flex with slightly more power than the general originally equipped the car with.
the reason im trying to drive the point about the t5 home, is that this argument happens about every 3 months, and its always the same thing.....like i said before im not taking aim at you, im making general statements about opinions on transmissions at large.....there are alot of trannys that are better than my tremec, most are very expensive, some aren't. However, there arent many transmissions that good that dont require alot of work to install in a 3rd gen
if you hang around automotive enthusiasts and racing for very long, you'll understand what i mean about arrogance in relation to what people use.
id also like to be on record as saying that i wish i had a real racing g-force or jerico 5 speed tranny, but i dont wanna shell out 4-6 grand for one
Reply 0
Sep 4, 2003 | 05:52 PM
  #91
OK - I understand what you're saying, but for a response like the one above, and to add some type of disclaimer that "I'm not taking aim at you" ......well...If ya read it, I certainly felt like I had a target on my back.
I've read numerous times about casing flex on T-5 trannys, but I've personally never brought it up on this board. So please don't catagorize me with people that bring this argument up every few months.
When I contacted G Force about the probs I've read about with T-5 casing flex, they basically told me that it's not the biggest issue these trannys have, and that they are not really any worse than others. He then re-inerated about having these trannys installed on sub 10 second cars, and they are doing fine with it.
Hey - these guys do this for a living.....everyone I spoke with said they were a reputable company, and they say they'd back up thier work, so I got a trans from them.
So I'm not here to debate over the casing issue. Besides, I don't trailer my car to the track and it's street driver 95% of the time anyway.
My only future plans with the car is to build a SBC 400 over the winter that'll hopefully crank out around 400 ft lbs, and hopefully around the same HP. And I knew for sure a purely stock BW T-5 isn't rated for it.
Regardless, I looked at getting either a Tremec or the G Force. The G Force was rated higher in both torque and HP, and I got it a few bucks cheaper. Will it cost me more down the road?? I'm sure the guy that installed the first Tremec in his car asked the same thing. And fact is, this trans is a pretty new thing from G Force, so the jury's still out.
Just try to not sentence me to death without a fair trail!
Reply 0
Sep 4, 2003 | 09:16 PM
  #92
What is a tremec case made of opposed to a stock T-5?
It's just cool to finally see some quality bulletproof part being made for a T-5. When I was first designing my 83 10 years ago, there was no way on earth to get a 5 speed (other than the richmond which you had to fab the tunnel to fit the external linkage) to hold anything over 300hp. Tremec has been around for a long time, unfortunately they have always had higher quality products for Fords until the 4th gens started to demand more.
I think I still have the car craft of when the G-Force came out with a trans that had straght cut gears 1st-3rd and heli's on 4th-5th. You use the clutch to come out out the hole, then full throttle clutchless shifts into 2nd and 3rd. Shifts into 4th & 5th with the clutch. It had an inline shifter settup that would let you downshift between 5th, 4th and 1st only. So you had to pretty much stop the car to get it back into 1st. Not ideal for the street, but ideal for my car that will eventually be street driven to the track. Do they still make that??? I didn't see it on their site. Now that I graduated I can finish the car the way I always couldn't afford to do.
Reply 0
Sep 4, 2003 | 09:41 PM
  #93
Quote:
they are both normally made of aluminum, what alloy im not sure of....but its not the material that causes the case issue, its the design of the case itself.
most high performance manual transmissions you see have ribs and other reinforcements cast into the transmission case to prevent case flex, t5's just never had any of this
Reply 0
Sep 4, 2003 | 09:44 PM
  #94
i know what you mean....but beware, if you plan on making that kind of torque....you ought to start thinkin about trailering your car to the track, especially if your launchin on slicks with a manual trans.
i didnt used to, until i learned the hard way....blew up a motor at the track and had to sit there for 3 hours waiting for AAA.
then i learned, and when i snapped an axle off inside my locker, i was glad that the trailer was waiting for me.
people talk all kinds of smack about "trailer queens" and what have you....until the get stuck at the track gate waiting for help until the middle of the night...its a nice precaution to take when you start making good power, and using sticky tires
Reply 0
Sep 5, 2003 | 01:54 PM
  #95
.... and make enough $$$ for a truck and trailor. I know you can try to find a friend with one, but like the quote said, the car is street driven 95% of the time. I would one day like my Z to sit on it's own trailor, but there are too many other priorities in front of that idea right now.
Reply 0
Sep 5, 2003 | 10:14 PM
  #96
the gears in the g-force are bigger then the stock gears..so obviously they take up more room in the case...
ok so the "weak ### T-5" case will flex, only nothing will break because the case cant/wont flex enough to seperate the gears to cause failure...
i was considering a T-56, TKO or this G-FORCE
but i already have the "case"
Reply 0
Sep 6, 2003 | 10:21 PM
  #97
the trailer i have right now is a home made POS thats been in the yard here for years, and i just happen to have plenty of trucks cause we own a fence company, but you can get a POS truck prety cheap....my truck is a beat up 89 gmc 1 ton with 170k miles on it
Reply 0
Subscribe
