Any "Royal Purple" users?
Old Apr 26, 2003 | 09:11 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I need to put new fluid in my T-56 and was hearing a few things about the Royal Purple company.... Any users? What are your opinions on it?
Old Apr 26, 2003 | 01:17 PM
25THRSS's Avatar
Don't use it. Ive heard their oil breaks down after a couple thousand miles. Don't know about the tranny fluid though.
Old Apr 28, 2003 | 07:58 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
WRONG!
Very good oil. Use it!
Old Apr 28, 2003 | 08:49 PM
25THRSS's Avatar
Might wanna check this out. Go to the thread entitled royal purple rocks under ls1 engine.
http://www.ls1.com/forums/
Old Apr 28, 2003 | 10:15 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
That is very interesting. At the plant that I work at they switched to Royal Purple and now instead of rebuilding the pump motors every eight months they go three years now. These motors run constantly without turning them off for three years. I'm still not convinced that it thins out. I am convinced that it is great oil. For a T-56 I'd definitely put some in it. I would say Redline is excellent also.
Old Apr 28, 2003 | 10:20 PM
25THRSS's Avatar
Yeah, i dunno about their tranny fluid, but there have been several engine oil analysis' that have come back showing very negative results with royal purple. That thread you read is just the tip of the iceburg. It seems like it is a great oil at first, but after a couple thousand miles the viscosity thins out a lot. After all the things I have heard about royal purple, I wont be putting it into my engine any time soon.
Old Apr 29, 2003 | 09:27 AM
Drakar's Avatar
Never used Royal Purple, but if your looking for something better go with Redline, that stuff I do use, in both tranny and rear, and it's good stuff.
Old Apr 29, 2003 | 01:34 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
:hail: Redline :nono: Royal Purple
Old Apr 29, 2003 | 10:28 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
any of you guys watch HP TV???? well you see the episode last season about the 2000 SS that they swapped Royal Purple into and dyno tested???? well that guy is a fellow Middle Tennessee Fbody member... and they put in Royal Purple motor oil, tranny fluid, and gear lube and he picked up 7 hp... dyno proven!!!!!
Hotrodboba400
Dec 10, 2019 07:07 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Night rider327
Sep 25, 2015 04:19 AM
gt4373
Sep 24, 2015 11:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
