estimated gains
Old Apr 27, 2003 | 10:32 PM
IROC of 88's Avatar
Car: 1988 IROC
Engine: See Signature
Transmission: B&M 700r4
estimated gains
I have a 2.77 rearend... and supposedly my car will have around 350-380 rwhp when it is done.... what kinda 1/4 mile time improvements would i see going to a 3.73 or 4.10 rearend??? i need to know if it is really worth the cash and effort to swap
Old Apr 28, 2003 | 12:53 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Oh man with a real power output in that area, you would see very significant gains assuming your traction is consistent. Considering how much difference shorter gears make in less powerful 3xx cube engines, I feel the decision is an easy one to make. Go real short... 410's I think you said - I agree!
I think a gain of at least .5 exists between 2.77s and 4.10's and with the power you have in mind that is a conservative guess on my part.
Old Apr 28, 2003 | 01:10 PM
IROC of 88's Avatar
Car: 1988 IROC
ummm keep in mind i am going to be running street tires... not slicks or street slicks... only street tires.... and i do not really have a stock 350.... it is quite built... somewhere near 380hp at the rear wheels.....
Old Apr 28, 2003 | 10:46 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
As you said in your intro post... I read things before I respond
Let me clarify that I assume you'll have the suspension to handle this kind of RWHP. If not, then keeping taller gears would help you to not spin like a ****, but IMO this is a band aid at best... the real way to go is to setup your suspension and get those short gears... As far as the use of street tires, well, they grip once you smoke in the box for a couple of seconds. My street tires managed a 1.88 60' recently at the track.... thing is, if you don't burn em, they suck ***... but we all know that anyway. WHen it comes down to a car that is running 13 - 14 ets I'd much rahter smoke a set of cheapo street tires than invest in expensive DR's or even StrtDR's... however, you are talking about some 12 second power... you have to do one or the other (smoke em or buy DR's) otherwise you are sacrificing some very significant traction! Just my outlook.
Old Apr 28, 2003 | 11:02 PM
IROC of 88's Avatar
Car: 1988 IROC
i have no problem smoking some tires... my brother owns a shop here and i get tires for cost... so that helps... if i could find a extra set of IROC rims i would put some fatty drag radials on them for at the track.....
Old Apr 29, 2003 | 08:57 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Awesome. So what exactly is the problem?
antman89iroc
36
Jan 31, 2016 08:42 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
