muncie T-10 swap
Old Apr 30, 2003 | 10:33 PM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
muncie T-10 swap
How hard would it be to swap in a Muncie T-10 in place of my T-5? my friend has one that was in his GTO so it has the pontiac bellhousing. Would the bellhousing from my T-5 fit? what else would be involved?
Old May 1, 2003 | 09:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Is it a Muncie, or is it a T-10? (Not that it makes a whole lot of difference as far as fit) They're 2 different transmissions.
It will fit your bell housing and clutch, if it's a M22 Muncie or a "Super T-10", since those have the 26-spline clutch gear. On the other hand, if it's either of those transmissions, your dirve shaft won't fit it, because it will have th Turbo 400 size yoke.
It will not have a torque arm mount, so you'd have to do something different to accommodate it; you can't run one of these cars without that, unless you re-design the rear suspension. I know of no shifter whatsoever for a Muncie in one of these cars, but there is (or at least was) a T-10 one available from Hurst, for 82 models that had T-10s.
It's not a direct fit at all, but some of the old transmissions will come closer than others. Sounds like you need to do some more research and find out exactly what thransmission this really is before you do anything.
Old May 1, 2003 | 05:56 PM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
go here http://members.rogers.com/1970-z28/muncie.htm and scroll to the bottem of the page it has a lot of info. I'm planning on doing a mucie swap into my third gen so if u got any questions just drop me an email at puremx13@yahoo.com
Old May 1, 2003 | 07:10 PM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
I talked to my friend today who has the trans and he said its a M-21 i dont know where i got T-10 from lol. I'm mainly concerned about the shifter coming up through the stock location becuase i dont want to modify my console or anything.
Old May 1, 2003 | 10:43 PM
SteveSpohn's Avatar
It's not a bad swap at all. The SCCA A-Sedan cars are running the T-10 now. We have a kit to install it:
http://www.spohn.net/index.cfm?fusea...&productid=137
Steve
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
