Installing a T5 in a TPI car...
Old May 1, 2003 | 11:19 AM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Hey all,
I swapped an '87 LB9 into my '85 Monte SS about 3 years ago, and kept the stock automatic in the car. The harness is from an automatic car, so it worked perfectly with my 200-4R. However, I'm getting bored with the car and my wife won't drive it, so I'm gonna be swapping a WC T5 into my car in a few weeks (more fun!). I'm already planning on changing to an '87 stick chip (it's on the way, along with the rest of the T5 conversion parts)and I had a couple quick questions for those of you that have converted an auto TPI car to stick.
* Did you change anything with the stock Park/Neutral switch?
* How did you wire in the reverse lights?
* Do I need to move anything else in the harness? In looking at my wire diagrams, I think everything else will function properly, but I wanted to be sure.
TIA!
Old May 1, 2003 | 12:21 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The neutral switch and the backup lights both get their information from the factory shifter in an automatic car. 4 of the 6 wires in the auto shifter harness are for these 2 functions, although their specific colors escape me. You can run the wires from the neutral safety switch to this harness and file down the small male-type quick disconnect plugs to plug directly into the factory harness, or you can cut and splice. Likewise, with the reverse lights, I ran the wires from the switch on the trans, through the old automatic shifter cable grommet up to the same harness and plugged it in the same way. Use a test light and you can figure out which wires are which, or wait for somebody else to chime in. If I remember I'll check my service manual, but I usually tend to forget about everything like that as soon as I leave work.
Old May 7, 2003 | 12:43 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Steve,
Should be able to pull the plug from the switch on the column and those two wires need to go to the two wires going to the trans. I never did this
The P/N switch gets disconnected from the column switch.
Don't forget to disconnect that useless linkage from column to trans., and go trew duels
Dats it.
Matthew
Old May 7, 2003 | 12:53 PM
Car: 1988 Monte SS
Thanks JMD. You da man!
Now, to find a plug at the partz store that matches the switch on the tranny.
Old May 7, 2003 | 12:58 PM
jmd's Avatar
jmd
I think it's a pretty standard 2 pin weatherpak connector; shouldn't be tough to locate. There's probably one a few blocks away on a black `03
edit: get back to work
Bubbajones_ya
Jul 6, 2024 08:32 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
cheesehomer
Dec 31, 2015 08:48 AM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
