Sometimes my TCC feels like it does'nt unlock at a stop
Old May 2, 2003 | 08:19 AM
MX265
Guest
Posts: n/a
Sometimes my TCC feels like it does'nt unlock at a stop. It intermittently stalls at lights also when this happens. Now my tranny is starting to slip between 2nd and 3rd. Of course it is a 700R4 tranny. Think it is time for a tranny rebuild?? I just swapped the fluid (yes it's at the right level) and also adjusted my TV Cable. Before I drop $1200.00 on a tranny rebuild, does anyone have any thoughts on this? Maybe I have a small animal like a possum nesting in my TCC. Seriously, does anyone have any input on this?
Thanks,
Andy
Old May 2, 2003 | 10:51 PM
Mike55TPI's Avatar
Andy, a friend of mine is a tranny guy at the local Chevy dealer and he mentioned to me once that the lock up solonoid is likely to do that.
Old May 2, 2003 | 11:54 PM
L98FORM89's Avatar
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
I have been having the same problem.When I slow down quickly feels like the TCC isn't letting go and I if dont shift into neutral and give it gas , it will stall. I thought maybe it was my brake booster or IAC goin bad. I am still not sure if this my problem (not sure if TCC is letting go or not) but it sure sounds very similar. Does this sound like your problem? I think I am going to have the soleniod checked next.
Old May 5, 2003 | 01:17 PM
MX265
Guest
Posts: n/a
Thanks for the replies. I found that I don't have this problem if I drive around in DRIVE instead of OD. Man I appreciate this input. Now I have to see about getting a new solenoid. Cool! Thanks!
Andy
Old May 5, 2003 | 01:28 PM
MX265
Guest
Posts: n/a
Is lockup solenoid the same as a Transmission solenoid?
Such as ATC 520203 TRANSMISSION SOLENOID available here under transmission parts:
http://www.partsamerica.com/PPF/Sour...PartGroups.asp
Thanks.
Old May 12, 2003 | 07:40 AM
MX265
Guest
Posts: n/a
Mike,
Ya just saved me a grand I think!!!! :lala: :hail:
I brought it over to my local shop that does most of my work for me (no time for DIY stuff with new 4-month old 3rd Genner in the house) They swapped out the solenoid in an hour and the car drives like new!! This has been a nuisance problem for months now and thanks to your insight, problem is solved!! I just used the extra money to get a Hooker Super Competition exhaust system!! Thanks man!!!
BTW, for you north Atlantan's, I have had the best luck going to Goodyear at the corner of Rt.92 and Bell's Ferry!! I have been going there for 4-years now, and Arron has always taken care of whatever issue I have had.
Thanks again,
Andy
Old May 12, 2003 | 08:31 AM
Mike55TPI's Avatar
Kool! Glad it worked out. That means money for more toys.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
85 Jimmy
Sep 30, 2015 07:56 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
