will this fit???????!?!?!
Old May 9, 2003 | 11:38 AM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
ok, i just bought a turbo400 tranny because my 700r4 transmission is blown in my car, so i bought a turbo400, the guy says it will fit with no problem, i just want a second opinion or more , will everything fit? like the driveshaft? the mounts? ect. thank you, please reply asap, thanks
Old May 9, 2003 | 12:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It will bolt to the engine, but that's about it.
Old May 9, 2003 | 02:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The driveshaft will not fit. The mounts will not fit. It doesn't use a TV cable, so that will not fit. It uses an electric kickdown system, which your car does not have. It does not have provision for the torque arm, so that will not fit (although you can get a kit to relocate the TA mount).
Other than that, it's a direct bolt-in.
Old May 9, 2003 | 02:19 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
RB: I know of the elec. kickdown; does the TH400 also have a kickdown cable similar to the th350-C in a 1983 Monte / Caprice?
87z28: I think that the mods necessary to install it, and lost mileage without the overdrive gear offset the initial appeal of the th400. I'd say not that you bought a tranny, but rather that you were sold one.
IMO...
Matthew
Old May 9, 2003 | 02:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, no cable.
Old May 9, 2003 | 04:14 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
You'll need a T400 adapter kit from Jegs, a shorter drive shaft and a different input yoke. Maybe some other stuff for the cables, cooler lines and vac modulator.
Miles
Old May 9, 2003 | 04:19 PM
jmd's Avatar
jmd
driveshaft length would depend on which tail length version of the TH400 he has. A short one would require a longer than stock (83-02) shaft.
Matthew
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
