tranny won't shift up!
Old May 10, 2003 | 11:01 AM
londonal's Avatar
Somebody help!
My 1985 305tpi z28 fitted with th700r4 won't shift out of first gear,pulls away fine but just won't shift up,any ideas?
Old May 10, 2003 | 12:23 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
On the drivers side of the transmission, all the way to the back of it, you will see a dome shaped cover. Pry it off and pull the Governer assembly out and see if the gear on the end is OK.
Old May 10, 2003 | 09:19 PM
gearhead86's Avatar
Something else you could check when you have the governor out is to make sure that the valve inside isn't stuck. Take the governor and hold it with the gear up and then press on the counterweights and make sure the valve inside moves up and down.
Old May 10, 2003 | 10:21 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
My tranny was doing the exact same thing. I checked the governor and couldn't find anything wrong. I just pulled the transmission out and I'm currently waiting for my Pro-Built 700R4 to arrive. I hope you have better luck with the governor than I did. You have the same transmission that I had and unfortunately it was the worst 700R4 that was made. They were built much better in '86 and beyond.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Formula_88AE
Sep 3, 2015 01:47 PM
