Installed the alum.d/shaft. A couple of ?'s
Old May 11, 2003 | 02:56 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Hi all,
Thanks for all the help in the installation, only took 20 mins Half the time was spent getting out and putting it in or out of gear to loosen or tighten the nuts!
The vibration I had at 90 has now gone up to 105-110mph, which is an improvement. It isn't actually a vibration but more a drone/hum- enough for me to stop pushing the throttle down. This only started after I swapped in my new rear end (2.77 to 3.32 or so BW 9 bolt with POSI) As the aluminium driveshaft has helped should I get it balanced? Any ideas? The U-joints I used looked great.....
Old May 11, 2003 | 11:36 AM
CamaroMike's Avatar
The larger diameter driveshaft moved the vibration up in speed. I think you have answered your own question though. "This only started after I swapped in my new rear end (2.77 to 3.32 or so BW 9 bolt with POSI)". I would be looking at a pinion bearing related problem.
Old May 11, 2003 | 03:52 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I would agree that there might be a problem in the rear. The aluminum d/s help eliminate those vibs, but there still could be problems in the rear. You might want to get some marking compound and check the wear pattern on the gears.
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
