tranny is slipping
tranny is slipping
ok for one, when i manually shift it, 1/4 the time itll go from 1st to 2nd without me moving the shifter from 1st....odd huh.. anyways, ...with the car in drive, going fron 2nd to 3rd, is like...slipping i guess.....itll go ...rrRRRRRRrrrrrr then go into 3rd. ...call will be hesitant during that period then, fine. so...any ideas?
Shifting into second gear when the selector is still in low is not uncommon. The rest of the symptoms are not good. Is the fluid still in good shape?, is the transmission still shifting ok at normal throttle openings?, If the answers are yes, then a Corvette servo with boost valves might keep this alive for awhile.
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
it only starts to slip after the car is fully warmed up and has been driven for about an hour. thatll teach me to manually shift the car all the time..DOH heh...actually when i manually shift the car, its perfect, doesnt slip....only slips when its in drive and has been driven for an hour or so....i havent changed the tranny filter or fluid since i got the car a year ago....is there a tranny drain plug?? --assuming there is-- ....dont ask, i seriously know nothing abut tranys, its pathetic
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
