This isn't right, is it?
Old May 14, 2003 | 06:08 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Hey everyone, I just put my LT1 intake on and Holley 52MM TB and the tranny cable isn't the way I think its supposed to be. I already slid the little black box thing (sorry, I don't know what its called ) all the way back, but theres still some slack. Any other way to pull it tight? Here is as at closed throttle:
Car: 1989 IROC-Z
Engine: 383 stroker
Sorry for the bad pics. Here it is a WOT and me givving it a little tug:
Old May 14, 2003 | 08:52 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
if it's like mine. I have a 92 camaro. look at where it connects the the bracket. now look just behind that you should see a half moon type shape there push it in and the cable should move in. if it doensn't you might want to push it in. now reinstall it to the trottle linkage. not take the linkage NOT the gas pedal and move it to WOT. you should hear the cable make a rachet type noise. this it done with the car off by the way. hope this helps.
Nick
Old May 15, 2003 | 11:15 AM
black85camaro's Avatar
Car: 85 Camaro
Engine: 350 Carbed
Transmission: Stock 700r4
I always thought that up pressed the gar to set the TV cable and not the linkage???
-Terry-
Old May 15, 2003 | 08:38 PM
Car: 1992 Camaro RS
-Terry-
I have heard that before to but the true way to do it is from the linkage. Thats how you get True WOT. Also thats what the helms Manual says. now if you pedal doesn't open it all the way you need to look at that.
Old May 16, 2003 | 01:01 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
when it is disconnected from the throttle body and you pull on the cable do you feel spring tension if not it may have come loose at the trans. just a thought
Old May 16, 2003 | 05:21 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Ok, I fabricated another bracket to move the slider back, then did the adjustment there (where I pull it through, then connect it, go to WOT and hear it ratchet through to adjust its self) so I thought I would be good to go. Now, when I drive, it shifts weird. First gear revs all the way up to 5500 when I floor it, then shifts to second, second gets high, then when I hit third I have problems. When it reaches about 2000, it stops accelerating and the engine just revs. It keeps reving til I get to 3000-3200, then it shifts hard. What should I do now? I don't wanna drive to too much and mess it up. I think I might just take it to a trans place Monday and see if they can fix it.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
