700-4r in an 83 camaro
Old May 15, 2003 | 04:14 PM
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
i have two questions, first of all, my car revs between gears and slams into gear exseasivly hard. any idea on what might do this? I was thinking some loose bands??? ok, sencend question. There is nothing more agravating then when your on the gas, and the car stays in third, and you have to get off the gas to make it shift, then you can only be half-way on the throttle or it kickes back down, how do i eleminate this? any info would be helpful.
Old May 15, 2003 | 09:17 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
you have to get a special kit
im pretty shure you have to get a special upgrade kit from like b&m that will make your tranny stay in OD wile you are at full throttle i think it like 35 bucks.
Old May 16, 2003 | 12:56 AM
82Z28NAZ
Guest
Posts: n/a
Re: 700-4r in an 83 camaro
I'm not sure what this is but my 85 with the 700 R4 did this before self-destructing. I'd get it fixed fast!
Monster is right on with the aftermarket valve changing the downshift point for the 700 R4. There are several versions of this that allow downshift at different amounts of pedal.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
