O-Ring on tranny filter
Subscribe
May 16, 2003 | 11:25 AM
Im changing my tranny filter and putting a new gasket on the pan, on my 700R4. Now my problem is, I was told that when I pull the old filter out, to make sure an O-ring comes out too. I took the filter out and no ring.
On my new filter, on the neck of it, there is a rubber looking ring, I assume that is the "o-ring". When I look into the hole where the neck of the filter goes, I see to what looks like that rubber ring thats on my new filter.
I attempted to install the new filter and I can not get the pan to go flat against the tranny. There's about a 1/2" gap. It seems like the pan is hitting something, which I now conclude is the filter.
What I am thinking is, should I remove that ring thats in my tranny where the filter goes? Cuz the ring itself is about 1/2" long and maybe I could push the filter up a 1/2" more and then the pan will fit?
Any help would be greatly appreciated!!
Reply 0
May 16, 2003 | 01:24 PM
"I was told that when I pull the old filter out, to make sure an O-ring comes out too. I took the filter out and no ring. " You were told correct, you need to get the old o-ring out. Why did you leave it in, if you were told it must come out? Just curious.
Reply 0
May 16, 2003 | 03:14 PM
I didn't leave it in on purpose, when i pulled the filter, the ring didn't come with it, the ring stayed in. Now Im picking at the damn rubber ring to get it out cuz it wont. grr
Reply 0
May 16, 2003 | 03:18 PM
yeah they can be a pain in the azz to get out sometimes. just have to keep trying
Reply 0
May 16, 2003 | 04:19 PM
Keep in mind that they are not simply a rubber ring that you can cut and then pull out... It is a metal ring surrounded by rubber (which seals)... I use an offset screwdriver (the ones that have a 90 degree flat blade on one side) to get stuck trans filter seals out...
Reply 0
May 16, 2003 | 05:05 PM
So... I should try and take the metal ring out with the rubber attached to it, instead of just getting the rubber part out?
Reply 0
May 16, 2003 | 07:32 PM
The rubber seal has a metal core... Yes, it will come out as one piece, but the first time I ever did it, I thought it was just rubber (and cutting it wasn't working too well). A small offset screwdriver (I got a set from Advance Auto Parts, since that was where I was working then) will pop it out real easily...
Reply 0
Subscribe
