Blueprinting a 10 bolt + disaster pictures
Old May 21, 2003 | 01:08 AM
ta84-355's Avatar
Car: Trans Am -84
Engine: 355, Twin Turbo
Axle/Gears: 3.73 open
Man, sometimes life just .....
I've got a 10 bolt 7.5" out of a 96 Trans Am. It died after 1500 miles on my TA-84. I guess it was removed from a wrecked car and that something may have been wrong in the first place. This rearend has costed me about 800 USD (not cheap here in Sweden) - so I'd like to rebuild it.
Is there some way to blueprint this rearend to see if something (except bearings + gears) are missaligned?
Doesn anyone have a blueprint or assembly guide for this rearend that I can download?
The rearend died going at 40-45 mph and that tore the gears into pieces. When I took it apart I saw that the bearing on the incoming axle was totally ruined.
Pictures can be found here:
http://www.tacs.nu/members/m006/breakdown.html
Thanks in advance for any help
Anders
Trans Am Club of Sweden (620+ members).
http://www.tacs.nu
Old May 21, 2003 | 05:38 AM
ede's Avatar
ede
it's hard to tell much from your pics. make sure the measurements are all correct, pinion depth, pinion preload, carrier preload, torque on bolts, every thing clean, i use red loctite on the bolts, use new ring gear bolts, new pinion nut, weld the axle tubes to the center houseing, use a girddle for the rear cover.
Old May 22, 2003 | 01:06 AM
ta84-355's Avatar
Car: Trans Am -84
Yeah I know, the pictures are bad and they're from before disassembly.
What I need is an assembly guide with torque numbers and other relevant numbers.
I've searched the net but it looks like noone has such a guide on their homepage.
Guess I have to order a book on the subject from the states - would be nice to order the needed parts at the same time, the freight costs are killing me.
/Anders
Old May 22, 2003 | 05:48 AM
ede's Avatar
ede
you ought to buy a manual if you don't already have one. try www.sethirdgen.org for a how to guide
Old May 22, 2003 | 09:39 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
http://www.2quicknovas.com/happyrearends.html may help.
Old May 23, 2003 | 12:51 AM
ta84-355's Avatar
Car: Trans Am -84
Very nice info, thank you very much!
/Anders
Frozer!!!
Jan 19, 2024 04:55 PM
chubsworth
Aug 26, 2015 02:34 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
Elliswon
Aug 10, 2015 12:33 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
