Convertor doesn't lock up anymore... what gives?
Old May 22, 2003 | 01:56 PM
BlacKnightsZ28's Avatar
I have an 86 Z28 with a de-computerized 383 in it. The tranny is a rebuilt 700R4 (The original tranny grenaded) with a lockup torque convertor and a 2500RPM stall, and a Eaton limited-slip posi rearend with 3.73s.
For the past little while, the convertor has stopped locking up. It used to always lock at around 40+mph when I was in 4th, but it doesn't lock at all anymore.
Is there a limit to how much torque a locked convertor can take? Could it be a fluid level issue or something like that? (I did check the level and it looked OK).
Comments or suggestions?
Old May 22, 2003 | 02:12 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
It won't lock up without a computer to tell it to.
If you have a manual switch or a vacuum switch or a 4th gear switch to lock it and now it isn't working, well either the switch is bad or the solenoid is bad.
You'd have more problems than no lock-up if you were low on fluid.
Old May 22, 2003 | 02:21 PM
How can I tell if it's a manual switch or a vacuum switch? It was locking before, and then it started not doing it every once in a while, now it doesn't at all.
Where would I find those switches?
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
sailtexas186548
Aug 24, 2015 10:11 PM
