torque converter lockup harmful?
Old May 24, 2003 | 11:14 AM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
with the torque converter lockup switch described in the technical articles, is harmful to your transmission at all to drive with the torque converter locked up?
Old May 24, 2003 | 12:16 PM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
You should have the torque converter locked in 4th gear for shure do to the gearing in OD. I would think it would be hard on you engine to lock it in lower gears do to the lugging (Load at low RPM's) I have mine lock in 4th (OD) only.
Old May 24, 2003 | 12:39 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Less heat will be produced in your transmission with the converter locked into a 1:1 ratio.. Less heat is always good for your transmission, so yes, lockup is good!
customblackbird
Oct 1, 2015 04:30 PM
88rscamar0
Sep 23, 2015 09:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
TheExaminer
Sep 7, 2015 08:34 AM
