Tranny Cooler Recomendations?
Old May 27, 2003 | 02:16 PM
MX265
Guest
Posts: n/a
Is this a good choice for my '89 IROC with 700R4? Summit part# SUM-G4960 which is accesable here:
http://store.summitracing.com/partde...rt=SUM%2DG4960
Or do you folks prefer B&M? Any input is appreciated.
Thanks.
Andy
Old May 27, 2003 | 02:38 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Get the biggest one you can find, I have the B&m. My tranny guy said to by pass the radiator and hook up the cooler straight to the tranny, cause the cooler in the radiator was a flow restriction. My $.02.
Old May 27, 2003 | 11:30 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
http://www.kdsperformance.com/haytranplush.html
Here is the one that I have. It works just as good as the B&M. My buddy has the B&M and we run about the same temps. This is better than the Summit cooler you are looking at. The Summit is only 16k-18k GVW. The Hayden is 24k GVW and is only cost about $3 more.
Old May 28, 2003 | 07:49 AM
MX265
Guest
Posts: n/a
Thanks for the input. I am going with a B&M 19,000 GVW. Is there alot of Tranny fluid leakage during the install? Also, I am assume more tranny fluid will need to be added due to the extra empty space.
Thanks again.
Old May 29, 2003 | 09:27 AM
OMINOUS_87's Avatar
jfreeman74
Wow! What a sweet deal! That cooler looks just like a B&M. Is it built the same way, as a high pressure unit? What an awesome price, is that the cheapest you know of?
Old May 29, 2003 | 02:31 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
My buddy has the B&M and there is nothing all that different between the two. The dimensions are a little different but that it is it. The B&M is a little more rectangular and the Haydan is more square. That is it. That is the lowest price that I could find. It's where I got mine from.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
apie2546
Sep 5, 2015 07:40 PM
