700r-4 Leaking
Old Jun 1, 2003 | 10:10 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
700r-4 Leaking
I noticed today that my tranny is leaking. It seems to be making almost a basket ball sized leak on my driveway after just 2 hours of sitting.
Is there any gasket that is prone to failing that I might be able to change myself? I am already going to change the pan gasket.
Old Jun 1, 2003 | 03:57 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Can you tell what part of the tranny it is leaking from? (front, back, middle) It it is the front then it is probably the front pump. Middle is the pan and back is probably something in the tailshaft.(speedo cable maybe)
Old Jun 1, 2003 | 07:21 PM
Pro Built Automatics's Avatar
Pan gaskets rarely leak. Take a paper towel and wipe everything down, go back in a half hour or when you see it leaking and take a white paper towel and dab around (above the pan) till you find where it is coming from, now you will know what to do.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
