what TC to get??
Old Jun 3, 2003 | 05:24 AM
SlowMaro's Avatar
what TC to get??
whats a good TC?? what stall should i get?????
Old Jun 4, 2003 | 01:04 AM
Boxeat2469's Avatar
Get a Torco converter. They are cheap, and they work awesome. You won't find more friendly people to do business with. I beat on mine daily both on the highway and on hard supercharged launches and it works flawlessly.
Old Jun 4, 2003 | 05:11 AM
SlowMaro's Avatar
what stall?? do they have a web site??????
Old Jun 4, 2003 | 08:18 AM
Boxeat2469's Avatar
http://www.torcoconverters.com
Talk with Mickey over at Torco. He'll ask you a bunch of questions about the car and your setup, then he can recommend the right converter. I'd say get the 9.5" lock-up unit with a 2800 RPM stall.
Old Jun 4, 2003 | 10:36 AM
OMINOUS_87's Avatar
I bought a Vigilante. Havent run it yet though but I have no worries about being disapointed.
Old Jun 7, 2003 | 03:11 PM
SlowMaro's Avatar
i found a decent reman. one around here for 90 bucks heh not abad deal, ...good warranty and all.....so , im thinking a 2200 stall????? will that be good for the mods i have?
Old Jun 7, 2003 | 04:01 PM
vjo90RS8's Avatar
Car: 2002 Z28
do you know how much power those Torco 9.5" converters can handle, pretty cheap for a 9.5 LU
Old Jun 7, 2003 | 04:55 PM
SlowMaro's Avatar
so .....should i specifically ask for a lock up....and is my tc electric or what??? for the mimmionth time, i know NOTHING about tranny crap....any site with tranny info / tc info????
Old Jun 7, 2003 | 06:42 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I would recommend a Midwest Convertor (www.raceconverters.com). I just got a 2800 stall for my car for $345 shipped. It works great. Just call them and tell them about your setup and they design it specially for your needs. Do you know your RWTQ and at what RPM it peaks at. Ideally you what a stall that is 400-600 less than your peak TRQ RPM. I would get a low STR around 2.0 - 2.2 if you take it to track much.
Old Jun 7, 2003 | 08:09 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i plan on goin with the torco converters for my th350 tranny and stallin it to 2800. a few things, someone asked this before, how much hp can one take? 2. whats the difference between lock up and non-lock up converters? is one used with the computer or no? becuz i have no computer set up in my car.
Old Jun 7, 2003 | 10:07 PM
Boxeat2469's Avatar
The Torco units are good for 500+ HP. Before I bought one, I e-ailed 4 guys that had bought Torco converters for 700R4 trannies. Of the 4, 3 replied back. All 3 had nothing but good things to say. Thats why I decided to try them. Now after the service I received and the quality of the converter, I will always use them for my converter supplier. I launch damn hard, pulling 1.6x 60 ft times consistently. Never had a problem with the converter. As far as which converter to use, a lock-up is pretty sweet. Nice high stall for killer launches, but zero slippage when you're cruising along. If you don't have a computer, you can wire the trans to always lock the converter in 4th gear. Or you can get the TCC lock-up kit that includes a vacuum switch that will lock the converter only under light loads / high vacuum conditions.
Old Jun 7, 2003 | 10:28 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
well i dont have a 4th gears. i only got 3 (th350 tranny). basiclly what does the lock up part do? i dont understand a TC very well, but if i get a non-lock up converter what will be the difference from the lock up?
Old Jun 7, 2003 | 10:55 PM
Boxeat2469's Avatar
The lock-up stuff only applies to the 700R4 and 200 trannies. The turbo 350 doesn't use it. Or at least 99.9% of the 350s don't. They did make a 350 w/ lock-up for a couple years, but odds are you don't have that style. Any RPM below the "stall speed" of the converter means there will be slippage and power loss between the motor and trans. A lock-up has a clutch inside the converter that engages and creates a direct mechanicl connection between the motor and trans, just like with a stick car. The lock-up allows you to get better gas mileage when cruising since there is no power loss at the coupling.
Old Jun 8, 2003 | 01:51 AM
SlowMaro's Avatar
question, what part #??? for a 92 camaro ,check sig for mods. if the sig didnt show up ill post the mods. also, ...i dont want TO high of a stall, i want something near 2200
Old Jun 8, 2003 | 04:30 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
The Torco converter is a 9-11, It is a 9.5 with an 11inch back L/U..looks like a UFO. Ive heard good and bad about these converters...They were selling them on ebay. I almost bought one.
They had a "normal 9.5 pictured, but sent out the 9-11. Kinda shady if you ask me.
https://www.thirdgen.org/techbb2/sho...ighlight=torco
Old Jun 8, 2003 | 04:43 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
That's going to be a waste. You will barely be able to tell a difference from the stock converter.
Old Jun 8, 2003 | 08:06 AM
Engine: 406
if thats all the stall you want, look into the Vette converters.
Old Jun 8, 2003 | 03:28 PM
SlowMaro's Avatar
ok so im gonna go for the safe side and get a vette TC.....im real tight on budget here heh....i honestly am not going to see past 300 hp when all is said and done......i dunno, ill try to get as close to 2500-2800 as possible without going over 150 bucks..oh and isnt the stock stall something like 1130??
Old Jun 8, 2003 | 05:23 PM
Engine: 406
here is your answer....http://www.lnjstreetrods.com/products/v8_converter/
Old Jun 8, 2003 | 05:24 PM
Engine: 406
or check on vette converters at your local parts store.
Old Jun 8, 2003 | 10:10 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Stock is 1600. I don't think 400 RPM is worth changing it.
Old Jun 8, 2003 | 10:18 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Are you replacing your transmission or is the converter the only thing you are doing? I just don't think it is worth the money or time that it will take to replace the convertor just for 400-600 extra RPM.
Old Jun 9, 2003 | 04:32 AM
SlowMaro's Avatar
yes the tranny is being replaced this week, the tc i have on the car now got cracked/sprung a leak, and killed my trnny by not delivering fluid .....so yeah...WISH i had money saved up to get a raptor tranny but im getting what i can "napa reman" yeah i know it sucks but they will let me make 200 dollar payments on it monthly, and thats the absolute best i can do....i have no credit. bank wont give me a loan. i wish i had an extra oh...3 grand saved up to get the GOOD stuff but...gotta get what ya can affoard....oh well. i mwaiting for the sun to come up o yank the heads off of a 350 today. --wish me luck-- i HATE taking stock manifolds off, especially with that damn air box in my way
Old Jun 9, 2003 | 04:36 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
$200 payments; I hope you don't have to make too many of those for that transmission.
Old Jun 9, 2003 | 08:54 AM
SlowMaro's Avatar
nah, 600 bucks, factory warranty ...id rather have a 50 state garunteed warranty than a local shops rebuild *warranty* ....im moving soon so id rather not have to tow the car back to sc to get a new tranny.....
