v6 vs v8 700r4 tranny??
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
no and yes
a V6 from a thirdgen camaro (2.8 or 3.1 both 60* blocks) will not
a 4.3 V6 found in trucks and mid 80's cars yes (because its the same bolt pattern as a SBC)
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
It would be eaister to find a V-8 tranny. I don't even know of an adapter plate but then you would need to get a different driveshaft and torque arm so stick with a V-8 tranny if your going to have a V-8.
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
the v6 700r4 in the thirdgens also has fewer clutches then the v8 version. if u adapted it to fit, it probably wouldnt last longer with the extra load you put on it from the v8.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
