End Caps on Driveshaft fell off...
Old Jun 3, 2003 | 10:07 PM
Steve89GTA's Avatar
Recently bought an aluminum shaft off someone on this board. When it was removed from the doner car, it appears that the caps(with needle bearings in them) aren't secued on at all. Isn't there supposed to be a set of c clips to hold them on?
Right now, the caps come off VERY easily. I have a feeling that they were secured on the previous car by the straps only.
I was surprised that they just came off so easily.
The needle bearings are very smooth though and are lubricated well. I'm wondering if the c clips from my steel shaft will work on this aluminum shaft since the joints look to be the same....or should I just get a new u=joint pressed in?
Thoughts?
Old Jun 3, 2003 | 10:13 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I would replace the u-joints.
sweet_87_iroc
Sep 25, 2015 10:01 PM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
Camarothatcould
Aug 20, 2015 08:49 AM
