WIll a t-5 from a V6 work with a V8?
Old Jun 3, 2003 | 10:35 PM
Metallica383's Avatar
I was wondering if I could use the tranny out of a v6 to use for a v8?
Thanks:hail:
Old Jun 3, 2003 | 11:03 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Im pretty sure it will. You have to have a v8 t5 bellhousing tho. I know a guy that has a v6 t5 in a 305 tpi. He said he gained low end but lost high end with it.
Old Jun 4, 2003 | 05:34 AM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
it will work but you will need the bellhousing for a v8......now how long that v6 "non world class" t-5 lasts is another question
Old Jun 4, 2003 | 10:58 AM
machinist's Avatar
Has everyone forgotten that a V6 car has a course input shaft spline, and a V8 car has a fine spline?
The trans will bolt up, but you will need a special clutch disk to make it work. Do a search and you will come up with the part number and manufacturer of the special clutch disk.
Old Jun 4, 2003 | 11:25 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
IIRC the clutch from the an astro van ends up being right, i don't remeber though, you can get the correct spline count, in a 10.4" clutch.
Old Jun 4, 2003 | 12:51 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
v6 clutch with v8 pressure plate.
But considering how fast you'll blow it up, I really wouldn't bother.
Old Jun 4, 2003 | 09:48 PM
Transmission: 4l60e
I know a guy that has this done behind a 305 TPI and its doing pretty good. I wouldnt do it tho. Id be afraid to run a t5 world class v8 tranny behind my 350.
Old Jun 4, 2003 | 10:25 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
go to McLeods website and order a 10 inch 14 spline clutch
the astro van clutch will not work because its too big (designed for the 168 tooth flywheel, which you cannot use either because the T5 bellhousing will only fit a 153 tooth flywheel)
the V6 clutch disc is too small, i know of people using it behind a V8 and it slipped horribly
Old Jun 6, 2003 | 06:14 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
get a truck bellhousing, even the old iron ones 67-72, but some of the 68 and older oens have 5" hole, we used a 68 iron sm318 bellhousing from a truck when we put in a sbc400 in an 82 firebird that had a 2.5, we left the saginaw 4 speed in behind the 400, we had to dent firewall a little down at clutch pedal linkage under car to let the iron truck fork travel enough, i know someone with a 69 chevy pickup with a muncie car four speed with the 5" opening truck iron bellhousing, he carefully centered the tranny and installed the four bolts and hasnt had any problems yet even after a coupel years now.
there are two heights of throwout bearings though, would need tall truck version
Old Jun 8, 2003 | 01:32 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
Does anyone know if you can run a saginaw 4 speed with the factory hydraulic setup? Or would you have ot go mechanical linkage?
Old Jun 9, 2003 | 02:44 PM
Jim85IROC's Avatar
The stock one would probably slip, but I doubt that an aftermarket, such as a Centerfoce D/F would slip.
But honestly, a little slippage might help save the tranny from fragging all over.
PurelyPMD
May 5, 2016 04:57 PM
DARKmj16
Sep 9, 2015 04:07 PM
Cacike
Aug 27, 2015 05:10 PM
GTARob
May 8, 2001 12:16 PM
