Searched but no luck..TC lockup switch
Car: 2002 Formula Firebird
Transmission: 4l60e
Ok I read the tech article and it didnt help all.
Which wire do I need to ground out? And how should I run the switch? Do I need to splice a wire into the wire then run it to a switch then to a ground?
I need some help. Im trying to figure it out so I can lockup the converter in 4th so I get better milage.
Im gonna get the b&m or painless wire kit after thirdgen nationals but Id like to be able to lock the converter up before making the trip.
Its really simple, all you have to do is tap a wire into the top furthest left side of the aldl connector under the dash, hook that up to one side of a toggle switch, take another wire hook it up to the furthermost right top of the aldl and put that to the other end of the toggle switch, and when you want it locked you just flip the switch.
Transmission: 4l60e
OoOoOooO Ok. Thats cake.
Will I be able to feel the TC lockup so I know its working?
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
just a reg. toggle wt a light on it, but I did not connect the light at all. I am going to try again I guess. BTW thanks for the quick response!
Car: 91Z
I had one on the neg. and one on the pos. and nothing on the light prong. Think I would be better with a two prong toggle?? It does not matter what end the + - go to on th ALDL does it?? Sorry for all the question's, I just wanna try it again tonight.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Originally posted by 88Camaro350
will this still work if you dont have the computer hooked up in the car at all???
Car: 91Z
In the tech section, they say something about a carb, so that lead's me to believe that it will work, but at the same time I wonder how it would still even be connected to the aldl at all??
Move the wires closest to each other i had the same problem when i had one wire on each side of the toggle switch and it didnt work , all i did was move one wire over on the switch, so both wires were right next to each other leaving the end prong of the switch open and it works perfectly now. Try this and go for a drive and let me know.
88Camaro350:
My computer is still in my car but its not hooked up to anything and my tc switch work just fine.
88Camaro350:
Transmission: 4l60e
Ill give it a try when I wake up tomorrow. Hopefully Ill get slightly better milage on the interstate.
Im gonna eventually just get the kit that locks it up. I want to install a drain plug in the pan to.
Car: 91Z
Nope, did'nt work!! I think it is because when I installed my B&M shifter, I never used the relay for the TC lock-up, so now the shifter is not hooked up to the TC at all. That is my only thought??
Ghettobird52
Jul 5, 2024 11:18 PM
someone972
Aug 30, 2015 12:52 AM
(1991 5.7)
