What does the regular transgo kit come with?
Old Jun 4, 2003 | 02:46 PM
Gen X Mar0's Avatar
Car: 1991 Z28
Engine: 5.7 Stealth Ram
Transmission: Pro-Built 700R4
Does it come with the corvette servo, .500 boost valve, and .296 intermediate/reverse valve?
Is there stuff I should also look at? I have seen the pro-built kit and am curious to the advantages of what it includes as opposed to the regular summit kit??
Old Jun 6, 2003 | 02:58 AM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Mine came with plugs ( to cap off holes in the seperator plate) a couple of drill bits, valves and springs for the valvebody and front pump. Plugs for the valve body and front pump, springs for the 3-4 clutch pack. I had a friend pick mine up, no vette servo, or .500 valve. Not sure exactly which kit he got, but it was over $110 wholesale. Hope this helps!
Old Jun 6, 2003 | 02:08 PM
JPiroc87's Avatar
I had the same question myself about 1,5 year ago and I asked Summit about the boost valves and the servo, but I didn't get any satisfactory answer (I did get a reply though; -a phone number to TransGo). The reason I even asked from Summit was shipping and handling charges because of my location. I was ordering other parts from Summit anyway, so I could have saved a great deal of money. But, since I couldn't get a straight answer from Summit I ordered from Probuilt: shift kit, accumulator kit and boost valves+servo. The boost valves and the servo are not included in the TransGo Reprogramming kit 700-2&3. This is what I found in my box (which parts you should install depends on your application):
Parts list:
 TV valve.
 Tapered spring for TV valve.
 Small brown spring for TV valve.
 Large red spring for TV valve.
 Rectangular spacer plate for TV valve.
 Two shims for TV valve (7.7/5.5 mm washers).
 Small 3-2 control valve with white spring and end plug.
 Large 3-2 control valve with yellow spring and end plug.
 Green spring for pressure regulator valve.
 Snap ring for pressure regulator valve and boost valves.
 Blue spring for line bias valve.
 Red spring for line bias valve.
 Orange spring for 3-4 shift valve.
 Three solid 5.6 mm steel plugs.
 Brown check ball
 2.8 mm drill
 4.9 mm drill
 Two square aluminum plugs for the separator plate.
 Two round aluminum plugs for the separator plate.
 One very small aluminum plug for the separator plate.
 Solid 6.2 mm steel plug.
 Two 7.6 mm bushings with 1.6 mm hole.
 Yellow ø19 mm spring for servo (Do not install).
 Three thin and three thick 22/13 mm washers for servo (Do not install).
 Governor spring for stick shift option.
 Spring kit for 3-4 clutch and forward clutch.
 Two separator plate gaskets.
TransGo Accumulator kit
Parts list:
 Orange spring for the 1-2 accumulator.
 Blue spring for 1-2 accumulator.
 Spring seat for 1-2 accumulator.
 Two accumulator piston seals.
 Blue spring for 2nd servo piston.
 Orange spring for accumulator valve.
 Brown spring for accumulator valve.
 Black spring for accumulator valve.
 Pink spring for line bias valve.
 Red spring for line bias valve (another).
 Blue spring for line bias valve (another).
 Brown check ball (another).
 Green spring for pressure regulator valve (another).
 Snap ring for pressure regulator valve and boost valves (another).
 Shim for band adjustment, size of servo.
Servo and boost valves
Parts list:
 .500 boost valve.
 .296 intermediate/reverse boost valve.
 2nd servo piston and housing.
 Red O-ring.
 Black O-ring.
 D-ring kit; totally five seals for the servo.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
327IROC85
Sep 23, 2015 12:11 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
