This normal?
Old Jun 4, 2003 | 05:37 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
This normal?
My 700R4 was rebuilt just over a year ago. The tranny shifts into 1st gear at about 3200 rpm, into 2nd at around 3200, and into third at around 2700, all under on light to medium throttle.
The shift into 1st and 2nd are hard, hard enough to squeal tires in the 1-2 shift when under heavy throttle. At WOT it shifts at 4500 or so. When in 1st the car moves slowly, rpms build fast, then it shifts, same thing happens in 2nd. It only acts funny when cold, its like the car is bogged down(could it be engine?). Also, at 35-40 mph it hunts between 3 and 4 gear.
Any of this normal?
What are the shift points(in rpm's and mph) of the 700r4?
Thanks,
Matt
Old Jun 4, 2003 | 07:13 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Try to reset you TV cable and see it that helps.
Old Jun 4, 2003 | 07:16 PM
Matto'85TA's Avatar
Already tried. Will do it again though. All you have to do is pull it and let go right? I have a 305 TPI.
Matt
Old Jun 4, 2003 | 11:55 PM
Tony89GTA's Avatar
Car: 89 GTA
I think so, its been a few years since I had a automatic in the car.
Old Jun 5, 2003 | 11:47 AM
Morley's Avatar
The "hunting" gear may actually be torque converter lockup engaging/disengaging, this was a problem on the earlier 700R4 equipped cars.
To adjust the TV cable, follow the instructions in the tech article, if after doing that it is still acting up on the shifts, try lengthening the cable 1 notch after setting it , if it improves but doesn't fix it completely, try going 1 more notch. I wouldn't go more than 2 notches longer than the factory settig though.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
