tranny destroyed HELP??
Old Jun 4, 2003 | 09:23 PM
JayHodge's Avatar
Car: 1987 Iroc-z
Engine: 5.7L 350
Transmission: 700 r4
I was being stupid, yes i no, im kickin myself right now, .... i was sitting at a dead stop but the car in neutral rev to 5k and slammed into drive....the car to say the least jumped, thuded (the tranny did) and the shifter console like jumped right up....and then it spun tires and took off...
well after this stupid stupid stupid action, the automatic shifter console and **** when i take off now jump up like its going to hit the roof. and when i get on it from 1st 2 second there is like a grinding shhhhhhh then it stops...
any suggestions?? what this is or who to repair???
thx
oh yea my grandpa said maybe a motor mount or, crossmember???? maybe? i havent raised it yet to look under it
Old Jun 4, 2003 | 09:57 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I'm not sure about the grinding sound but the jumping definitely sounds like the transmission mount broke.
Old Jun 5, 2003 | 12:13 AM
Adam Jones's Avatar
Shortly after I had my 700r4 rebuilt I accidentally did a neutral drop on the freeway (shifting from neutral to drive/overdrive while at high RPMs).
A little while later, my transmission got REALLY messed up. It wouldn't go faster than 35 mph in overdrive, and made a horrible groaning noise while downshifting.
The backpressure from the high RPMs snapped the forward clutch piston in half, at least that's what the shop said. Luckily it was under warranty, because it had to be RE-re-built!
-Anthony Helton
Old Jun 5, 2003 | 05:53 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, you broke your transmission mount, like everybody who has one of these cars does sooner or later.
Get an Energy Suspension or Prothane one, don't bother with a stock replacement, it'll just break again like they always do.
Fix that first. You may find it fixes the noise too.
Old Jun 5, 2003 | 11:56 AM
JayHodge's Avatar
Car: 1987 Iroc-z
Engine: 5.7L 350
where
i have no idea what that is, where is it located? do i have to drop the tranny or anything to replace it??
where can i get one and for about how much thx??!!!!!
Old Jun 5, 2003 | 01:52 PM
TJs57TPi's Avatar
ur trans mount is located on the trans crossmember which is attached to the back of ur trans and connects to the frame, u do not have to remove the trans, just keep it supported and in place with some kind of jack and a wooden board or somethin to prevent denting your trans, the easiest way is if u have air tools just take the whole crossmember off, 5 bolts, put a new mount in, polyurethane is the best, and just bolt it back up....right guys?
Old Jun 5, 2003 | 02:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://store.summitracing.com/partde...NS%2D3%2D1108G
Don't use the preload plate, you don't need it
Old Jun 5, 2003 | 02:05 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Yup I'll also say transmission mount is what's causing the clunking. It's easy to replace, don't worry.
1.) Get your car SECURELY on jackstands.
2.) Get a decent floor-jack under the car and support the transmission at the pan with a block of wood between the pan and the jack (so that it doesn't have all the support force in one spot). Raise the jack enough so that the transmission just barely starts moving up, so that you know the support is at the jack and not on the crossmember.
3.) Remove the four bolts on the crossmember (the bar running sideways across the transmission supporting it), two on each side.
4.) Remove the center bolt on the crossmember. That rubbery-looking, weird-shaped thing is the transmission mount. It should all be one piece. If it's in two pieces, it's bad.
5.) Installation is reverse of the removal. ;-) Make sure you've got the crossmember on and torqued down well before you lower the floor jack.
FormulasOnly
Jul 23, 2018 08:47 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
