350 not fitting to drivetran
Car: 86 Z28
Engine: 383
Transmission: built 700r4
I'm doing an engine/tranny swap in my 86 z28 and I measured the 350tranny comepared to my 700r4, I noticed that it falls a little short and wont reach the drivetran right,
I know people have done this swap, how do you make hook up right?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
short tail th350 are about 28 5/8" long overall and longtail th350 and 700r4's are exactly 3" longer, you shoulda got a truck th350, they are the length of the 700r4's
it will probably be harder to find a thm200c driveshaft than it would be to find or trade for longer th350
there is a 700r4 that is shorter than all other 700r4's- thats the corvette one
Car: `86 SS / `87 SS
You need a longer driveshaft. You cannot lengthen a driveshaft. The vette 700 & 4L60 do not help in this situation.
Car: 4
Engine: 6
Transmission: 5
It is extremely easy to lengthen a drive shaft. I've had numerous ones done over the years.
THey chuck it up in a vise, turn the tube off of the yokes, and weld in a new piece of tube of the desired length. It's so easy for somebody with the right lathe, it's just about a license to print money.
Check with any place around your area that services big trucks (18-wheelers and bigger). It's needed for them all the time.
Car: 87 Formula
Engine: 355
Transmission: TH400
Axle/Gears: 5.00
Go to the bone yard and get a drive shaft out of a monza. That is what I ran in my 84 Z28 when I took out the 700R4 and replaced it with a TH350 ( Short Tail ).
Originally posted by RB83L69
Wrong.
Wrong.
-Matthew
