What's causing this grinding?
Old Jun 10, 2003 | 10:14 PM
Eric_7810's Avatar
Car: 1986 Z28
Engine: LG4 305ci
I have an 86 z28 with a T5 tranny. when i need to shift to reverse I put the clutch to the floor and it wont go into reverse without grinding and slamming, I am also beginning to have problems shifting into 1 gear when I am at a complete stop. Is this caused by a bad clutch? Is my clutch wearing out? Please explain this to me, and the best way to have it repaired, thanks alot. Eric
Old Jun 11, 2003 | 07:08 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Reverse has no synchronizer. It will always do that. Before you try to put it in reverse, put it in a forward gear first to stop all the guts inside it from spinning, then it will go right in without grinding. Of all the things I hate to see when I buy a transmission core, it's that exact lack of correct driving technique that bothers me the most; I've seen too many otherwise cherry transmissions ruined by all the metal chips that got shed into the fluid by a driver that didn't do that, and ended up ruining the transmission.
The other problem probably is a clutch issue, probably a worn-out pilot bushing; if that's dead, then the rest of the clutch can't be far behind.
Replace the clutch, and learn to drive a stick shift better.
Old Jun 11, 2003 | 07:40 PM
Eric_7810's Avatar
Car: 1986 Z28
Engine: LG4 305ci
No Crap
That is exactly what i do, i go into 1 gear before going into reverse, but that aint solving it anymore, it is still grinding it a little bit. The clutch needs replaced, thats all, but thanks for reply
Old Jun 15, 2003 | 12:30 AM
Odyssey's Avatar
Well if all the "guts" in the transmission are at a complete stop by you putting it in first, then it's impossible for it to grind! Grinding is only possible when something's spinning.... RB's got a good point.
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
