Leaks
Leaks
I have a few things leaking on my car... one being the power steering fluid which I have no idea where its leaking from, anyone have some suggestions for that? But more importantly I'm leaking transmission fluid from the shift linkage or somewhere around there, how would I go about fixing the leak?
first i think you need to determine, where exactly it is leaking from. put the car up on ramps or something and get some light down there. You should try pulling your pan off and see if the leak was coming from the gasket. once you get that off, you should be able to see better, and determine where exactly the leak is coming from.
good luck.
good luck.
