ls1 t-56 in an 87 GTA
Old Jun 12, 2003 | 06:26 PM
polygaryd's Avatar
Car: 1994 firebird
Engine: 427ci lsx bowtie block
Transmission: tremec t56 micro edged gears
Axle/Gears: Strange dana 60 with racing spool
hey i need some info on what i can use and what i can't use from the 2000 ls1 t-56 i have. everyone says i need a new flywheel from an lt1 which is fine but then can i use my new clutch pressure plate and disk from the 2000 ls1 t-56 or do i need boht new ones of those also how bout the hydrolic throwout brearing? from the new ls1 t-56? and do i really need the new input shaft from an lt1 t-56? can't i just use my new ls1 flwheel with new bolt holes to line up with my l98 crank? and then keep eveyrthin from he ls1 t-56???? someone help me out here
Old Jun 12, 2003 | 09:43 PM
kevinc's Avatar
Car: 1982 Z28
Re: ls1 t-56 in an 87 GTA
You'll need to swap the input shaft, swap the bellhousing, use an LT1 flywheel, not sure about the clutch and pressure plate, and learn how to spell hydraulic.
Old Jun 13, 2003 | 12:02 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Is the spline number the same, I thought it was more of a distance issue than the actual input shaft?
Old Jun 13, 2003 | 09:17 AM
kevinc's Avatar
Car: 1982 Z28
Don't know, once you get to the distance thing you've pretty much ruled out using the input shaft. Given that McLeod now makes bellhousing adapters which allow the LS1 T56 to be used on a regular SBC the shaft thing may not require swapping it...but there's $$ involved.
In most cases, people end up w/ an LS1 trans because they got a good deal on it. By the time you get done buying all the stuff you need to make it work w/ a regular SBC, you probably spent more than you saved.
Old Jun 13, 2003 | 10:11 AM
polygaryd's Avatar
Car: 1994 firebird
ls1 hydrolic clutch with lt1 flywheel
hey first of all i was tired when i posted this article so my speeling can be off. second i need to get a whole new bellhousing with the clutch fork too??? which would mean i cant use my hydrolic throwout bearing either right?? still why can't i just use the ls1 flywheel with new bolts holes drilled in it or have one made with the correct bolt holes. and keep all my ls1 stuff. that way it should be the same length..correct or no?
Old Jun 13, 2003 | 10:29 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Save yourself some time and headaches, sell the LS1 stuff and get the LT1 setup, it bolts in without all the extra cost.
Old Jun 13, 2003 | 07:36 PM
polygaryd's Avatar
Car: 1994 firebird
ls1 and lt1 t-56
the ls1 handles more hp and torque... i want the ls1
Old Jun 13, 2003 | 11:35 PM
kevinc's Avatar
Car: 1982 Z28
Re: ls1 and lt1 t-56
Really? What is the rating for the LS1 version compared to the LT1 version?
Old Jun 14, 2003 | 09:17 PM
Dan88IrocZ's Avatar
Re: Re: ls1 t-56 in an 87 GTA
Why are you so harsh on the guy? Not everyone graduates from Harvard with a major in English ya know..
TX-SleeperC5
Feb 24, 2016 01:34 PM
tonys91rs
Oct 10, 2015 03:31 PM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
timonator
Sep 10, 2015 07:55 PM
