tranny leakage
Old Jun 19, 2003 | 02:01 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
tranny leakage
well, i went to change my tranny fluid, even though i knew it leaked BAAAD!! i knew it was out so i changed it even though the poor 'ol T5 has still been shiftin great! well, i fill it up and when i get back under to put the fill plug back in (i had a leak where the shifter mounts, so i filled it from the top) i look and to my total SHOCK there is fluid all over the ground!!!!! i put in Lucas tranny fix and maxlife tranny juice. it looks as if the max life is all that leaked out (the thin ****) so i MAY still have some Lucas in her. the weirdest part was this, the leak appears to be coming from where the torque arm mount bolts to the tranny! how is this possible? is my casing cracked? if not, how do i fix this? this appears to be the leak that is draining my tranny. it will be built this summer, but i'd like to keep it drivin on until then...and suggestions?
thanks in advance!
Josh
p.s.- i have to have the car as a daily driver, so parkin it ain't a feasible option...
Old Jun 19, 2003 | 06:44 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
hey josh, im josh too.
uhm, sounds like your leak is maybe the electro speed gear seal. i don't much about the manual tranny's but i'm guessin it has a tailshaft too. i would pull the torque arm off, lower the tranny and pull off the tailshaft. the seals are really cheap at any parts store.
hope this helps. good luck.
:rockon:
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
