T-56 transmission swap on an 86 Camaro with a T-5.
Old Jun 19, 2003 | 02:29 PM
Thomas_Simon's Avatar
Car: 1986 Camaro Iroc Z28
Engine: Carburated 350 V8
Transmission: T5 - 5 speed manual
I'm doing a T-56 transmission swap on an 86 Camaro with a T-5.
I have the T-56 but need to know what other parts I will need to complete the project.
I know I need a new cross member and all the clutch parts but need more details and if possible the part numbers.
Thanks for any help you can provide.
:hail:
Old Jun 19, 2003 | 09:59 PM
DABE's Avatar
speedo box from dakota digital ($200)
hydrolics (spell) for the t56...
Old Jun 20, 2003 | 12:36 PM
kevinc's Avatar
Car: 1982 Z28
Most of the GM part#s can be found on the Sallee Chevrolet website if you dig around, all the way down to the bolts.
Old Jun 20, 2003 | 01:36 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
gonna need the adapter plate to mount it to the t-5 bellhousing, the vss, crossmember, torque arm, proper hydrolics, and a shortened driveshaft. spohn sells all the parts needed for the swap just click the link!
Old Jun 20, 2003 | 10:15 PM
DABE's Avatar
u dont need the adapter plate if he is using the t56 clutch and bellhousing and flywheel...
the way that 89RsPower! described is with the aftermarket t56 setup...which is more expensive than a complete used t56
Vintageracer
Jan 10, 2020 05:33 PM
reiderz iroc
Aug 13, 2015 04:57 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
cRoe4
Aug 7, 2015 08:46 PM
