transmission hp ratings...
Old Jun 18, 2003 | 07:58 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
alright, some of you have read about my project in the tech/general engine and the exhuast boards. i have for the most part decided on the motor for my "Mighty Mouse" small block. it will include a 355 with pro topline 235cc heads, big lift, blah, blah, blah! the main part of the motor is the d-3 procharger that will be forcing everything through with a bout 25lbs of boost. my question is, with the capabilties of over 1000 hp, what tranny should i go with. i have a guy in OK that can build me whatever i want for pretty reasonable. i need to know, however, if i should go with a:
powerglide
th350
th400
i know that it may seem strange to run an automatic but that's what i have decided. if any one could inform me on the gear ratio's of these trannies, suggested rearend gear w/ 28" tire, and the amount of hp to drive the tranny that would be appreciated as well.
Old Jun 18, 2003 | 08:04 AM
mjpell's Avatar
whch trans?
Definately not the TH350. As I understand it, the PGs are really only recommended for cars under 3000lbs.
I'd definately vote for a well build TH400.
Good luck!
Old Jun 20, 2003 | 09:37 AM
mw66nova's Avatar
Engine: 7.0L
anyone else?
Old Jun 20, 2003 | 05:27 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
gear ratios (stock)
th350 - first 2.52 second 1.52 third 1.00
th400 - 2.48 1.48 1.00
powerglide first 1.76 or 1.82 second 1.00
i'd put in a vote for a 350 or a 400.. a well built 350 is pretty much bullet proof same goes for a 400.. a 350 weighs less...
Old Jun 20, 2003 | 06:03 PM
mw66nova's Avatar
Engine: 7.0L
yeah, that's what i thought that i had heard too. i thought that the th350's would be alright if built right, and the guy that is building mine will definelty build it right!
Old Jun 20, 2003 | 06:07 PM
89RsPower!'s Avatar
yep as far as stock goes they arnt anything too special, but lookin at all the mods your doin to the engine i really didnt think you were lookin for a stock trans
Old Jun 20, 2003 | 11:57 PM
mw66nova's Avatar
Engine: 7.0L
so, what would guys recommend gear ratio wise with a th350 and a 28" tire?
Old Jun 21, 2003 | 12:25 AM
91 Camaro Z28's Avatar
4.10
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
