where can i get some speedo gears??
Old Jun 26, 2003 | 07:13 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
hi i am swapping in a 4th gen rear end with 3.42 gears.
i have everything execpt the speedo gears. i don't kow where to get them.
i have an 89 iroc 305tpi/700r4.
can someone give me a link or something that would great. thanks jonathan aka wyclef
Old Jun 26, 2003 | 07:23 PM
Ovrclck350's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=186930
Any GM dealer. I'm assuming you're switching from a 2.73 in which case it's easier to use a 45T gear (although your speedo will be off 2%)
Part no. for that gear is: 25513052
Pics are in that other thread.
Old Jun 26, 2003 | 07:56 PM
Engine: peanut LB9
thanks, but can i get the one from 700r4 and it will still work??
thats the green on correct the 45 tooth one. and what do u mean that it will be off 2%, my tires are a little under sized. will it be off. so at 65 i will be really doing 66.5 or 63.5???
thanks-
Old Jun 26, 2003 | 08:55 PM
Ovrclck350's Avatar
THe one from 700R4 is for cable driven speedo's.
The one I bought can be ordered fom gmpartsdirect for like $3.50.
I don't know about with undersized tires, but with stock tires, at 98MPH your speedo will read 100. At 49, it'll read 50.
You CAN get it dead on if you feel like removing the tailshaft and replacing the drive gear too.
Old Jun 26, 2003 | 08:57 PM
Ovrclck350's Avatar
http://www.gmpartsdirect.com/
It's $3.09
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
