Tranny Squeels
Old Jun 26, 2003 | 07:55 PM
Kaas's Avatar
Car: 89 Iroc-Z
Tranny Squeels
I have a 84 z-28 5 speed (think it's the T-5 they put in those) anyways, i just recently moved from the east coast to the mid-west and drove my car, relitevly light load on it, heaviest thing in it was a TV. Anyways, i was going up one of the mountains in WV and i took it in 5th when i probably should have taken it in 4th. Since then my car has had a squeal in first second and third gear. One of my buddies and I think that it's the flywheel, i was just wondering what you guys thought, maybe save myself some cash rather than taking it into a tranny shop to just find out what's wrong with it.
Old Jun 26, 2003 | 08:09 PM
ChaosRanger's Avatar
Car: 1984 F41 T-Top
Transmission: 5 speed
Not a tech ...
Check for loose bolts on:
housing-to-engine,
transmission-to-clutch
Change the transmission oil and look for metal.
That fifth gear and or bearing(s) may have been damaged for taking on too much load ...
Old Jun 26, 2003 | 10:33 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
the trany has two sets of bearings, a front and rear set. the main portion of wear is going to be in the first three gears which really beat on teh front bearing. if it squeals only 1-3 gears then its most likely the front bearing. i had a similar problem but the damage was bc i put gear oil instead of atf in the trany. smoked it in 2 days.
Old Jun 28, 2003 | 08:50 PM
Kaas's Avatar
Car: 89 Iroc-Z
well, my car broke down yesterday, smells and sounds like the clutch went in it, tho i think the tranny has some damage done to it
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
