t-5 finally blew!!
Old Jun 30, 2003 | 08:42 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
t-5 finally blew!!
get this I have been running this t-5 for quite some time now years. and have chewed up rear end after rear end but sat I put in a 9bolt 3.45 and decided to take it for a quick ride. I made sure everything was well worked in all the diff fluid had time to go from axle to axle. I gave it a little as I was comming up a hill the as I slid it into third it made a sound like when someone misses a shift so I pulled back on the shifter right away and then let off the clutch and all I could hear was a clunking. tried 3rd again as I was costing down the hill and nothing, so I tried all the other gears with no problem but, still the clunking noise, so I limp it home (around the corner) pull it apart and third gear and the counter shaft are destroyed. the counter shaft has no teeth at all for 3rd and third geat is missing a whole bunch of teeth.
what gets me is why now? oh well I guess but, does any one know who sells a counter shaft for a 88 t-5 that does not cost 300+ I can find the 3rd gear every where even beefy ones for the trans (30teeth) but the only counter shafts I find are nuts wtf for a little more you could have a used t56
Old Jun 30, 2003 | 11:25 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: t-5 finally blew!!
I dunno, but you gotta admit, you got your $ out of the tranny
I'll see what I can do tomorrow.
Old Jul 1, 2003 | 04:30 PM
jmd's Avatar
jmd
You have mail
Old Jul 2, 2003 | 05:40 AM
Spdfrk1990's Avatar
i have a t-5 also i heard that 3rd was the weak gear in them. I was thinkin about maybe just rebuilding it instead of goin with a 6-speed. Does ne1 know if you can actually get the t-5 rebuilt to withold some hp.
Old Jul 3, 2003 | 12:04 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I blew mine a couple weeks ago. The whole 3-4 assembly was in pieces. Not to mention I lost the input shaft bearing thus wiping out the mainshaft and probably the input shaft, couple syncros looked like they went through a garbage disposer, and it broke a shift fork! I pulled it and there were a bunch of metal in the bottom and the fluid had a silver color to it from all the shavings.
Old Jul 3, 2003 | 12:07 AM
kfoley's Avatar
Car: '85 Z28
The G-force kit will hold 600 hp w/ drag radials and a moderate clutch, but it'll set you back $1600 ($200 more if they install it) for the kit, or $2000 for a built tranny straight from them.
Old Jul 3, 2003 | 05:57 AM
Spdfrk1990's Avatar
well thats stupid cause u could get a t-56 for that. I would get a world class heavy duty t-5 b4 i spent that on that kit.
Old Jul 3, 2003 | 11:17 AM
kfoley's Avatar
Car: '85 Z28
Yes, but T56's are only rated to 450 tq. You can get a WC T5, but they're only good for like 300 tq. or so. I'm not saying it's exspensive, it is, but if you're running a lot of power you're tranny's going to be exspensive if you want it to hold. I don't have the money now, so the kit isn't an option. We'll see how the WC T5 holds up to 500hp and 550tq. As long as I don't abuse it (i.e. powershift, clutch dump) I'll be alright.
Old Jul 3, 2003 | 06:42 PM
Spdfrk1990's Avatar
The add i was reading on the wc said it held up to 600 and said it was virtualy bullet proof.
Old Jul 4, 2003 | 12:07 AM
kfoley's Avatar
Car: '85 Z28
Are you talking about the ad for a G-force tranny or a stock WC T5. The stock ones are far, far from bullet proof... cap gun proof, maybe, but not bullet proof...
Old Jul 4, 2003 | 12:09 AM
Spdfrk1990's Avatar
the add said it was a heavy duty one it was in jegs catalog
Old Jul 4, 2003 | 12:13 AM
kfoley's Avatar
Car: '85 Z28
What's the part number on it?
Old Jul 4, 2003 | 12:16 AM
Spdfrk1990's Avatar
it might have been in the ford section ill check tomorrow but arent the camaro and ford t-5's the same??
Old Jul 4, 2003 | 12:38 AM
kfoley's Avatar
Car: '85 Z28
Kind of... Internally I believe they are basically the same, but I do know the cases are different. They won't work in Chevy's.
Old Jul 4, 2003 | 12:39 AM
Spdfrk1990's Avatar
ugh ok then so wouldnt they make the same 1 for a chevy tho like the same internals
Old Jul 4, 2003 | 01:54 AM
kfoley's Avatar
Car: '85 Z28
Well the internals are basically the same, but not identical. For some reason the beefed up T5's are more popular for Fords than for Chevy's, why that is so I don't really know. I would think it would be about the same. If they did make them for a reasonable price though, I think there would be a good market, but since all the kits are ridiculously priced they're not in high demand.
Old Jul 5, 2003 | 12:37 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
https://www.thirdgen.org/techbb2/sho...hreadid=175170
If youre gonna build it yourself, the drop in kit from G-Force is only $950 for everything.
Old Jul 5, 2003 | 10:58 PM
kfoley's Avatar
Car: '85 Z28
The $950 is for the gears 1-4 ONLY. That does not include a mainshaft or 5th (overdrive) gears. The kit for the entire tranny is about $1600. I've got the price sheet around here somewhere, and I've also posted the prices on another thread in the transmission forum.
Old Jul 6, 2003 | 04:15 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Has anyone in here actually broken a mainshaft? Anyone here powershift into 5th and break the O.D. gears? Does anyone here shift into 5th when they drag race? I keep hearing about countershafts breaking. Hell, my RS had a broken countershaft when I got it (input shaft gear and the mating gear trashed). Even G-Force said that unless youre doing some REALLY EXTREME STUFF, you dont need the mainshaft. I would consider the steel shift forks though.
$1600? Not necessary...
Old Jul 7, 2003 | 03:15 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
You can mate them up but you need a custom adaptor plate to mate to the chevy bellhousing. I am not sure if they are mass produced but a guy over at corvette.com made his own since mustang t-5's are plentiful and he is an engineer. Seems with the number of f-bodies and mustangs somebody would make a adaptor plate like they do to mate a chevy th350 to a buick/olds/pontiac block.
Old Jul 18, 2003 | 01:57 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
I believe the problem is the shifter location on the mustang t-5. It is way forward in relation to a fbody t5.
Old Dec 24, 2003 | 03:04 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I blew my WC T5 yesterday... first it was hard to shif out of gear.. then the whining got louder... then it started to knock... then I got the shifter into the neutral position... and it was still in gear... then WHAM back wheels locked up!
Old Dec 24, 2003 | 05:42 PM
Engine: ls1, LB9
sounds bad, are you going to open it up and see what let loose?
Old Dec 24, 2003 | 05:44 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Guess I'm stupid then.
Old Dec 24, 2003 | 06:36 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
88 350 tpi formula sounds bad, are you going to open it up and see what let loose?
I dunno... I don't think it's something that I'm up for! Can I do it with a Chiltons?
Old Dec 24, 2003 | 10:53 PM
Engine: ls1, LB9
well, I don't think the chiltion goes into it well if at all. but, I think if you feel you can take the trans out, do clutch jobs ect. (nothing real major just the basic knowledge of how things work) then yes it is a very simple trans. if you plan to fix it I guess it depends on whats wrong. like mine it was not worth fixing and every one wanted way too much for a used t-5 so I said forget it. got the t-56 for even less than the t-5 counter shaft alone!
if you just want to see whats going on inside ,there are plenty of us who have taken them apart. and if you want same the other way too.
I think I had left a link to a sight that shows the t-5 break down and assembley instructions on another post
Old Dec 24, 2003 | 11:09 PM
Engine: ls1, LB9
http://www.ttcautomotive.com/English/products/T-5.asp
I know it says tremec but, it should still be the same or atleast close enough since tremec bought it or bought out borgwarner? can't remember it's not like it matters anyway
Old Dec 25, 2003 | 01:09 AM
kfoley's Avatar
Car: '85 Z28
Chances are whatever blew will be more exspensive than a new (used) T5, but it would be good experience to crack it open and take a look at it. There's not a whole lot to them really.
Old Dec 26, 2003 | 11:09 AM
jmd's Avatar
jmd
Dizamn is all I can say there. I remember sending you prices for the countershaft and you flat out stole a T56 if you got it for less than that.
Old Dec 26, 2003 | 07:06 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
everything has to break sometime. It probably wasn't the new rear that broke it, its the hundreds of hard launchs and shifts prior to that. I have a friend who constantly asks, well why did that break then? It's gotta go sometimes.
I don't know how GM T5's compare to Ford's T5's they put in mustangs but I have tried to help my friend put his frod T5 back together twice, that thing is a cluster #$%#. I am a mechanic, but have zero knowledge of the inner workings of a manual gear box. We had a half *** diagrahm, it didn't help, he ended up taking it to a local rearend shop and had them put it back together. He blew reverse out of it, and some countershaft or something. I don't remember.
Good luck.
Jason
Old Dec 26, 2003 | 11:02 PM
Engine: ls1, LB9
I posted this a very long timeago. I know the rear did not make it break.
FormulasOnly
Jul 23, 2018 08:47 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Gordonr1973
Sep 29, 2015 11:59 AM
