reverse & low valve
Old Jul 5, 2003 | 09:11 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
reverse & low valve
I am installing the small(green box) Transgo kit in my tranny, the only valve it came with is the throttle valve. I purchased a .500 boost valve also, should I put a new low reverse valve in at the same time? I noticed that the big kit from Pro-Built includes the low/reverse valve, as well as a larger boost valve.
Old Jul 6, 2003 | 01:22 AM
Pro Built Automatics's Avatar
Measure the intermediate/reverse boost valve and see what diameter it is? It should be .282. If it is or if it is larger than this, you are ok, unless you do a lot of manual shifting, then I would go to the .296 boost valve. By the way I would add the Corvette servo, while doing this, it will help firm up 2nd and 3rd gear.
Old Jul 6, 2003 | 08:50 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Thanks, I usually just let the tranny shift itself anyway. I already have the Vette servo installed.
deracer
Apr 11, 2016 12:04 AM
MoJoe
Sep 24, 2015 09:12 PM
Rakim_RS25TH
Aug 27, 2015 05:04 PM
NBrehm
Aug 25, 2015 11:49 PM
mizz0313
Aug 12, 2015 06:45 AM
