PLEASE HELP.Whats wrong with my tranny dosent shift to 2nd inless i slam the gas.
Old Jul 12, 2003 | 07:16 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Okay i was driving around town and the firebird was shifting fine then i try to put a tranny fluid cooler so i cut the line thats on the top.Of the radiator and put a hose and a clamp on it and then the end to the tranny cooler and then i put the exiting part of the cooler back to the radiator and then it goes back to the tranny.So i get in the car and go slow then try to spped up but the car wont shift to second it foes all the way up to 3200 rpm befoe i floor it then it shifts up in to the other gears.So i say im going to take the cooler off so i route everything back the way it was so i go and test it and it still does the same thing.
So i check the fluid level and i add it to be perfect fluid level and it still does it.Please i really need to know what wrong with my tranny its a 700R4 the car has 116 thousand miles.
Old Jul 12, 2003 | 08:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like you disturbed something else in the process that you didn't notice.... probably the TV cable (no I'm not talking about Time-Warner)
Old Jul 13, 2003 | 01:58 AM
tbfirebird's Avatar
Engine: ??????????
um the car goes in reverse normal and and would haveing the cooler mounted in anyway cause a problem.
Old Jul 13, 2003 | 08:30 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The cooler has nothing to do with the issue at hand, nor does reverse.
See the above post for clues.
Old Jul 13, 2003 | 12:48 PM
tbfirebird's Avatar
Engine: ??????????
how do i adjust the tv cable on the 305 tbi
also if its not that then what could it be?
Old Jul 13, 2003 | 07:23 PM
tbfirebird's Avatar
Engine: ??????????
Now the car jumps when i put it in to drive feels like it gets all 4 tires off the ground.
PLEASE HELP.
Dyno Don
Jan 24, 2016 08:24 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
