will posi make difference?
Old Jul 15, 2003 | 02:43 PM
daddy33's Avatar
Car: '85 Camaro
ok guys i just purchased a posi unit with 3.73 gears and will be installing it in a couple weeks. Right now i have a "one legged" unit with 3.08. I noticed when i try to floor it off the start, my car shakes because the car is trying to grab traction. With the new posi and 3.73 gears will i be getting off the start better? Will i be getting better acceleration when im at crusing speeds? im just curious the benefits i will get when i will put it in. I appreciate any info. Thanks!!
-Tino
Old Jul 15, 2003 | 02:50 PM
84 Z28 5.0 HO's Avatar
Car: 84 Camaro Z28
Engine: 305 L69
yes you will get much better off the line traction with a posi. The hopping you described may dissapear. With the new ratio you will lose some miles per gallon but it should give you overall better acceleration.
Old Jul 17, 2003 | 12:01 AM
STREET SLEEPER's Avatar
You will love the way you will lunch off the line, the wheel hopping should dissapper with great traction. 3.73 are awsome grears, I think, great all around gears, its true though, you will lose mpg, who carse though? Right? Have fun.
Old Jul 17, 2003 | 02:26 PM
82camaro's Avatar
Car: 82 camaro SC
However, with the deeper gears you will increase power to the rear wheels when launching and hurt traction. Posi will help out the traction problem, but isn't going to stop wheel hop. It may be worse, since now both tires will hop. If you still have wheel hop after the swap, check the suspension board for different fixes.
Old Jul 17, 2003 | 05:13 PM
andys86ta's Avatar
Car: 1986 trans am
Engine: 300hp 355cu. inch
Transmission: 350 turbo with shift kit and ratchet shifter
sounds to me that your struts are worn causing your hopping. Ihope your car has an overdrivng gear either 5speed or 4spd auto because it will rev like crazy top end.
Old Jul 19, 2003 | 01:34 PM
LetsRock's Avatar
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
My GTA has factory posi which I tested last night and was glad to see still is functional, this car has excellent traction or the motor isnt up to snuff, it took a dump of the clutch at 2500 rpms to get the tires loose, both broke loose and there was no wheel hop.
Old Jul 19, 2003 | 08:25 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by STREET SLEEPER
Its true though, you will lose mpg, who carse though? Right? Have fun.
Anyone who buys a car that only needs a 2L engine, but has 5L or more prolly didn't buy it for the awesome MPG, lol
It won't change too much though
Old Jul 19, 2003 | 08:43 PM
25THRSS's Avatar
Gears will not increase rwhp. They simply multiply torque in a way and get you into the power band faster, but if you measured it on a dyno you would gain nothing.
Old Jul 19, 2003 | 09:39 PM
The guy didnt say it would gain rwhp, he said it will increase lunching power. Which is true, you will take off the line faster, no HP gain at all...
Old Jul 19, 2003 | 09:51 PM
25THRSS's Avatar
"The guy didnt say it would gain rwhp, he said it will increase lunching power. Which is true, you will take off the line faster, no HP gain at all..."
Old Jul 20, 2003 | 01:22 AM
Momar's Avatar
Settle down there. Although not measurable on a dyno you do gain "leverage". Its not necessarily power, but will help in the same way.
Old Jul 20, 2003 | 01:26 AM
25THRSS's Avatar
yes I know, I was just saying it won't actually give you rwhp. You will definitely see gains at the track and feel it on the butt dyno, but the real dyno won't know any difference.
Old Jul 20, 2003 | 05:51 AM
spatter1's Avatar
Car: 89 RS
Engine: LO3
Transmission: TH700R4
I used to have that problem... it scared the s**t out of me when it happened. I didn't intentionally seek out to fix the problem, but I did develop a different problem in by rear end that lead to a rebuild. The rebuild lead to a 3.23 gear ratio over the stock 2.73 ratio and now I get the one wheel peel all the way through first along with a powerful CHERP into second at around 4500 RPM. No hopping. (Not to bad for the stock LO3).
I don't know if the rebuild has something to do with it or not but the carrier was broken (was that way when I bought the car - unfortunately I did not realize it) resulting in excessive play in the axle.
I'm looking forward to getting my posi rearend (with disk brakes) so I hook better (and stop!).
The thought of putting a posi in leads me to another question, if you know how to rebuild a rear end includig changing the ring and pinion, look for my topic psted on the board.
Old Jul 20, 2003 | 05:41 PM
Settle down there
Dont worry, Iam just blabbing, not at all getting upset or angry, just talking!!!
Old Jul 21, 2003 | 07:11 AM
Momar's Avatar
Re: Settle down there
Hey, I was just messing around. I was agreeing with you anyway that he didnt necisarrily post that he would gain rwhp just power to the rear wheels which could be interprited in more than one way.
Ben
hectre13
Dec 11, 2023 08:14 AM
onefreakz
May 14, 2018 12:15 PM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
novaderrik
Aug 10, 2015 12:44 PM
