People with Th350's
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
People with Th350's
How fast can you go and mat the gas and still get it to kick down......Tell me what set up you are running to please.
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
my th350 is not hooked up to the detent cable. this is no problem because the line pressure is so high during shifts the acuumulators fill up really fast and there is no slip.
the only thing i hooked up was the vacuum modulator, its important because it tells the tranny when your motor is under load and when to shift. the governer has lighter springs as well to make the shifts later.
its in front of a 2.77 geared 3800 Lb. car with a 240 horsepower van motor. very cheesy, but it handles itself nicelly for a stock tranny. it was behind a blown 355, but thats another story.
Car: 84 Z28
Engine: 355c.i.
Yeah i mean what is the max speed i can be going and Mash the gas and still have enough left to kick the tranny down a gear. 3.73 rears, thats what i was wondering, how fast you guys can do it at.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
depends on how many RPM's you want to see
whats your tire height ?
and 3.73 is your ratio, you say ?
you can find RPM calculators online if you search at yahoo/google home pages
Pac J
May 17, 2020 10:44 AM
MadOTC
Oct 13, 2015 04:46 PM
