swap 9 bolt disc brakes on 10 bolt
Old Jul 22, 2003 | 02:53 PM
Ringmaster72's Avatar
Car: 1989 IROC
Can I swap my 9 bolt disc brakes onto a 10 bolt disc rear without modification?
Tim
Old Jul 22, 2003 | 07:27 PM
irocz43's Avatar
Yeah, you can swap them no problem. I have an 89 which had that 9-bolt with a 2.77 gear. I just installed a 10-bolt out of a 92 with a new richmond 3.73 gear and mosier axles. All the brakes bolt up real easy. Now im kicking myself because i want a 12-bolt to handle my new motor. i only put 400miles on this rear end after $1200!! ....oh well
Old Jul 23, 2003 | 09:54 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yes they should work without too much hassle. seeing that you have a 89', there should be no problem(PBR rear brakes). i do recommend getting the disc backing plates for 10bolt though. that will make the swap even easier.
if you need the 10bolt backing plates PM me or email me. i have a set for sale.
Old Jul 28, 2003 | 09:28 PM
mhaskell's Avatar
I have a 92 10 bolt with the aluminum brakes, can i swap these onto a 10 bolt that has drums? Do i need new flanges?
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
