BENDING 700R4 steel lines
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I am almost done with my header/full exhaust install on my '87 IROC-Z.
My only problem is my y-pipe is not able to go up high enough because it is hitting the tranny lines. I need them to go up about 1-2 inches.
Is it possible to bend these lines? Easily? How prone are they to breakage?
HELP!!
HELP!!
Car: 4
Engine: 6
Transmission: 5
Yes. Yes. Not very.
Use a tubing bender. You can probably "rent" one at Auto Zone and those type places. You can even make new ones, or cut them off and flare them (using another tool you can "rent") and use a union fitting to hook them up.
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I wouldn't worry about breaking them, when I swapped my engine I decided to pull the tranny with it
, well I happened to forget about the lines and they ended up going into the A/C cooler (if thats what its called). Anyway they made a pretty big whole in the little pieces of metal, bent a little bit, but most of all held all the weight of the engine when I tried pulling it forward b4 I realized what was happening....So yeah I wouldn't worry too much about breakage
, well I happened to forget about the lines and they ended up going into the A/C cooler (if thats what its called). Anyway they made a pretty big whole in the little pieces of metal, bent a little bit, but most of all held all the weight of the engine when I tried pulling it forward b4 I realized what was happening....So yeah I wouldn't worry too much about breakage Supreme Member
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Be careful when you bend it. Make sure you done crimp it to the point where it restricts flow.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
