Tranny sometimes slips on 2-3 shift, but only at 6000 RPM+
Old Aug 2, 2003 | 01:55 AM
CamaroX84's Avatar
When I shift my 1984 700R4 trans manually, the shift between 2nd and 3rd is always nice and hard below 6000 RPM. When I go above that, sometimes it shifts hard, other times it slips. Sometimes it slips very mildly, sometimes very harshly, sending my motor to it's 7000 RPM rev limiter. What could be causing this?? What do I need to do?? Thanks in advance.
Old Aug 6, 2003 | 04:40 PM
Pro Built Automatics's Avatar
The input drum has a checkball that can unseat when there is not a enough volume of oil to bring on the 3-4 clutch pack (common). The Trans-Go Performance Shift kit will fix this in most cases, as it triples the volume of oil.
Old Aug 7, 2003 | 02:10 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Be careful using a shift kit to solve the problem. I did that and my 2-3 got worse and everntually slipped all the time. Sometimes a drop in fluid preassure can cause the same slipping problem or worn clutch pack. Even yet, check your kick down cable and be sure it is adjusted properly. Mine used to slip at only 5,000 or above, then it got worse as time went on.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
darwinprice
17
Oct 11, 2015 11:51 PM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
