9 bolt rearend?
Old Aug 2, 2003 | 12:18 PM
NonczRS's Avatar
Car: 1991 Camaro Convertible
Engine: GMPP 350
9 bolt rearend?
I am getting ready to throw some 3.73 gears in a rearend that I have had for a year or two. Unfortunately, when I looked at it I was confused it was not a ten bolt it was a 9 bolt..... I believe it cam out of an 88GTA.... it is supposedly a posi disc brake 2.73 rearend. What is the deal?
Old Aug 2, 2003 | 01:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
¿¿Deal?? I know nothing about this "deal" you speak of.
Ummmm..... it's a 9-bolt. A completely different model of rear end, made by a different mfr, from the 10-bolt. Absolutely nothing whatsoever inside it will interchange with the 10-bolt.
If you want to upgrade its gears to 3.anything, you'll need a different carrier, since the 2.77 is a 2-series carrier, and 3.27 and up use a 3-series carrier.
Old Aug 3, 2003 | 01:39 AM
NonczRS's Avatar
Engine: GMPP 350
Could I....
Then, would I be able to transfer my disc brake set-up from my 9 bolt to my 10 bolt that came out of the car.... ( 91 camaro 2.73 open)
Old Aug 3, 2003 | 09:33 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
not a direct swap. There is a tech article that goes over the swap in the tech article section on the main page.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
WickedBowtie
Sep 11, 2015 11:24 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
